Rear seatbelt prematurely locking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cantgoback, Sep 1, 2009.
  1. cantgoback
    cantgoback Junior Member
    santa rosa, ca
    Has anyone had any issues with the rear seat belts locking up during driving? This has happened to my wife in the rear seat on multiple occasions, and I don't know what causes it. She isn't intentionally locking it (by pulling the belt all the way out).
    By 'locking up' I mean normally you can pull the seat belt in and out smoothly (unless done abruptly), but when locked it only goes in not out, until it goes in far enough to disengage the lock. When locked you'll hear a distinct "ticking" sound while the belt is going in, which otherwise isn't there.
    Anyway, it seems like a defect, but just curious if anyone else has experienced this problem on their Gen3, or have had rear seat passengers complaining about it.
  2. Tideland Prius
    16,402
    What you've described usually only happens when you pull it all the way out so having that happen midway is out of the ordinary. I also assume you're not talking about the ELR which is locked when pulled abruptly (as you've said) but does not make a ticking noise. It just lets go when you retract slightly.
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I think you have a defective seatbelt. I've had this happen on other cars, but usually after some wear. I think you should bring it in to the dealer to get fixed under warranty.
  4. cantgoback
    santa rosa, ca
    OK that's what I was guessing too. Looks like I'll have to pay my dealer a visit. Thanks for the input.
  5. psu77
    psu77 New Member
    29
    Jacksonville FL
    Yes it happened to me too. One of my passengers complained in the back that it locked while we were driving. She had to play around with it to get it to unlock.
  6. cantgoback
    santa rosa, ca
    Did she have to pretty much release the seat belt altogether, and then re-insert the buckle to get it back to normal?
    I was paying more attention last night when my wife got in the back seat again. I watched carefully as she pulled the seat belt, and caught her pulling the belt all the way to the end, thereby triggering the locking mechanism. It took her a few tries to avoid doing that. We do have a baby seat in the center, so it gets pretty tight back there. In this situation, maybe buckling the seat belt is difficult enough to cause her to pull more belt than usual. So this suggests that maybe our seat belt wasn't defective after all.
    I also tried measuring the rear seat belt lengths to check if they were particularly short. The length from the dangling buckle to the slot on the seat was ~80-82", 3-4 measurements per side. I also measured a belt on our Sienna, and that was ~83". Not much difference there, so that's ruled out. It's most likely user error. I'll have to keep a closer watch. If so I apologize for the false alarm.
  7. bac
    bac Active Member
    863
    52
    Pennsylvania
    The seatbelt is designed to lock under a variety of circumstances. If there was ANY acceleration or braking or turning, the seatbelt may have locked as designed.
    -Brad
  8. patsparks
    10,664
    567
    Adelaide South Australia
    The seatbelt will make a ratchet noise after you pull it all the way out when putting it on and will retract but not extend. This is to secure child seats better. Make sure you dont pull the belt all the way out when putting it on.
    (someone already said this didn't they?)
  9. MK3.0T
    MK3.0T New Member
    Dallas, TX
    Throwback... the seat belt is getting stuck, the latch part. Anything else come of this?
