Rear speed-sensor harness
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Nov 11, 2023.
  1. nicoj36
    nicoj36 Active Member
    516
    161
    Replacing my rear-left speed sensor soon. Anyone know if it connects under the car or inside the car? if inside is it under the trunk by hybrid battery or do I need to take the rear-seats off? Thanks
  2. ASRDogman
    ASRDogman Senior Member
    7,007
    3,668
    The sensor is in the hub. you unplug it at the hub.
  3. nicoj36
    516
    161
    Sorry I meant the wiring harness. I know the other end connects at the hub, but where does the other one connect to? I've read somewhere its actually inside the interior by the wheel well
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,285
    5,659
    Texas Hill Country
    Replacing the cable or the sensor?
    Sensor is in the hub.
  5. ASRDogman
    7,007
    3,668
    I believe I saw it after pulling the paneling out. There is a connector that goes to the front
    of the car. I don't remember exactly where because it's been a few years.
  6. rjparker
    9,285
    5,659
    Texas Hill Country
    It appears to be under the rear panel. This was from my car about ten years ago.
    nicoj36 likes this.
