Rear view mirror floppy in hot weather
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Peter1, Jul 9, 2024.
  1. Peter1
    Peter1 Junior Member
    Rear view mirror hangs loose in warm weather, apparently from the ball joint. How can I fix this?
  2. tweedle99
    tweedle99 Member
    107
    62
    Round Rock, TX
    Depend on the condition of the socket. If the socket is not cracked, cut off tip of a latex glove and put it over the ball. This will give extra friction/shim to the mirror.
    If the socket is cracked, either replace it. I've end up putting gorilla glue on the socket. You can still adjust w/ the pivot closer to the windshield
  3. BK619
    BK619 New Member
    San Diego
    Try adjusting the hex screw at the bottom of the foundation. I think it’s a T10
