red triangle/exclamation point and icon on screen
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mattmonsour, Jan 23, 2010.
  1. mattmonsour
    mattmonsour Junior Member
    51
    Starting this morning a few seconds after I start my Prius the red triangle/exclamation point comes on along with a beep. The screen has a banner across the top for a few seconds saying "problem" followed by a strange icon. After a minute or so both go away and everything seems fine.
    After searching priuschat I THINK it has something to do with a headlight leveling sensor (didn't realize there was anything that fancy on a prius:) but no one has posted a pic either.
    Just wondering if someone could glance at the attachment real quick and let me know if it is in fact the headline leveling sensor or something else.
    I have been thinking for a few months now that my headlines weren't as bright as they used to be. I assumed I scratched the lenses scraping ice off of them in the ice storm here in KY last winter but maybe not.
    Thanks for any tips!
    Matt
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you're right.. it's the headlight leveling sensor. the sensor on the rear axle of the car will rust out..
  3. mattmonsour
    51
    Thanks! Now I at least know it's safe to drive and I'm not doing any serious damage.
    So, is this a $300 part like some have said? I'm not having any luck finding one online and don't have high hopes of finding one on a Sunday either.
    Don't know of a good place to buy one off the top of your head, do you? If it can only come from a dealer then it will mean quite the drive. The local dealer will never touch a car of mine after leaving me w/ an unsafe car and refusing to fix their screw up!
  4. Patrick Wong
    18,200
    6,490
    I think that you will need 89408-47010. MSRP is $347, you can buy it for $264 plus shipping here:
    Champion ToyotaWorld
    You can also try removing the old part, to see whether you can disassemble it and clean off the corrosion. If so, maybe you can save the $$$ associated with the new part.
  5. mattmonsour
    51
    Ah, part # that helps a bunch. Thanks again! I just bought a house yesterday so the timing SUCKS. I'll prob. come up w/ the money for the new one though.
  6. mattmonsour
    51
  7. Patrick Wong
    18,200
    6,490
    Hi Matt,
    I don't have personal experience with this since I haven't had to replace that level sensor yet. However, allow me to suggest what I would do: Disconnect the 12V battery negative cable first. Then raise up the rear of the car on jackstands, crawl under the car, find the sensor on the driver's side of the rear beam axle, remove it, and replace with the new part. Lower the car back down, then reconnect the battery.
    See if the headlight aim is OK. If yes, then you are done. If no, then you might have to ask for dealer help but at least you bought the part at a discount and hopefully the labor charge will be reduced.
    Good luck.
  8. Patrick Wong
    18,200
    6,490
  9. mattmonsour
    51
    Sounds like a good plan. Good point, can't hurt to swap the part, worst case it would leave me where I am now and save a bit of labor.
    I would not have though to disconnect the neg. terminal. Thanks
  10. Patrick Wong
    18,200
    6,490
    Yes, the reason to disconnect the 12V battery is that the headlight beam level control ECU receives 12V power at all times via the 10A GAUGE fuse. While you are deinstalling and installing the sensor, if the car remains powered up then you might be inputing out-of-range signals to the ECU that would confuse it and necessitate the reset using the Toyota diagnostic laptop.
    Anyway, let us know what happens after you've replaced the part. Good luck.
  11. fast48603
    fast48603 New Member
    The Dealer replaced my part for only the labor. I think this is a known problem but only will rplace when it fails. This was on my 2005 Prius. I now have a 2010 Prius.
  12. salsss
    salsss New Member
    Tupper Lake, NY
    I have this problem too. Why can't we just re-level the headlights to where we want them and go on with driving like other cars? Is this possible?
  13. Will D
    Will D New Member
    Columbus, OH
    Did you ever get this figured out? I've been having the same problem with my 2004 prius and I want to pay/labor as little as possible just to get the red ! out of my face! I see that there are headlight leveling sensors on ebay for under 50 bucks. Does anyone know if that's all that needs to be replaced?
  14. mattmonsour
    51
    I bought the part from the link earlier in this thread and disconnected the neg battery terminal as suggested. And everything is wonderful!
    the part is pretty easy to swap out. One wire (which was a LITTLE bit difficult to get off, but nothing major) and, if memory serves, 3 bolts.
    It was that simple for me! and, yes, my old one was very corroded. I couldn't help but take it apart and see and it was in pretty bad shape inside.
    Good luck!
    Matt
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I just posted on a similar thread: red ! triangle and yellow headlight symbol | PriusChat
    I would be careful of getting something off ebay unless you know it is the right part. Search the web for Prius height sensor unless the ebay picture is obviously the correct part. $50 is really cheap and if it isn't corroded would be a good deal.
  16. Patrick Wong
    18,200
    6,490
    This is an old question but was previously unanswered. Since this thread was resurrected, I'll answer it now.
    The point of having the HID headlights level sensor is that as weight is added or removed from the rear of the car which causes the headlights to move up and down, the sensor will provide info to the headlight computer to automatically adjust the aim accordingly. HID headlights are brighter than halogen, and Toyota engineers felt the need to include this auto level feature into their design.
    If you re-level the headlights without fixing the problem, then to the extent that you add or remove weight from the back hatch or rear seat, the headlight aim will be off. If the aim is high then you will irritate oncoming traffic. If low then it will be hard for you to see.
    dave77 likes this.
