Relay list
Discussion in 'Gen 2 Prius Technical Discussion' started by jelloslug, Jul 18, 2008.
  1. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    Does anyone have a list of part numbers for the relays that are in the fuse panel on the drivers side under the hood? Someone was nice enough to swipe them ALL before the car went to auction.
  2. Patrick Wong
    18,210
    6,510
    I'm hoping that you can get help from your local dealer on this. Otherwise, here is a link to the Houston, TX dealer that I buy parts from (since they discount at 25% off MSRP):
    Toyotaworld.com - Toyota Parts, Toyota Accessories, Genuine Toyota Parts, TRD Performance Parts, Champion Toyota Gulf Freeway, Houston, Texas
    I took a look at the relay box in my 2004, and there is a very large variety of relays installed. Generally the part numbers are not visible when the relays are installed.
    Thanks for pointing out in a separate post that only the Parking Control Motor relay is required to make the powertrain operate, since the other relays are for the ABS system and headlights... What warning lights come on, when you operated the car without those other relays?
  3. jelloslug
    813
    55
    Greenville, SC
    The ABS warning light is the only one I can recall at this time. I would check it again but the car is in about a millions pieces right now....
  4. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    If you're working on a salvage, which it certainly looks like,
    hopefully you've got all the service info from Toyota which I
    believe includes part numbers in some of the PDFs.
    _H*
