Remove speaker RSA and driver attention monitor
Discussion in 'Gen 5 Prius Technical Discussion' started by apm63, May 15, 2024.
  1. apm63
    apm63 New Member
    Netherlands
    2024 Prius Prime
    Business Edition
    Does anyone know where the speaker for the RSA/driver monitor alerts is located, so I can rip it out and throw it in the bin?
    The constant loud beeping of these alerts is driving me crazy...
  2. apm63
    apm63 New Member
    Netherlands
    2024 Prius Prime
    Business Edition
    As it is not possible to delete the beep in the software, it is the only way to shut it up I believe
  3. Zeromus
    Zeromus Active Member
    468
    240
    Ottawa Canada
    2024 Prius Prime
    SE
    The RSA thing in Europe is wild to me. I get why it exists, and there's some new regulation or something but from what I've heard it goes off the moment you go a single kmh or mph over the speed limit. Which, if true, is far too sensitive. It needs to have a range before audible vs visible alert IMHO.
    Driver monitor - mine rarely beeps at me unless I put my hand on the top of the steering wheel waiting to turn or looking out my rear view. Generally a bad habit I need to break though given the way airbags work. So if the driver monitor is beeping often, unless its tuned extra sensitive in Europe, maybe there are behavioural fixes to that one.
    And before anyone suggests that the speaker is under the grill on the dash behind the head unit, I've seen photos in threads before of that space and there's nothing there on any trim. Might have been a carryover design feature that just never was changed, or maybe its just ventilation for the electronics in the dash made to have a visual design cue of a speaker grill?
    50,801
    Idk if Europe is the same, but some people mentioned that there’s only one speaker for everything, and there are threads detailing the pedestrian warning system
  5. Hammersmith
    Hammersmith Senior Member
    1,875
    1,870
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They're talking about interior beeps, not exterior.
    As to the OP's question...
    There are some gen5 Prius models that have a speaker directly behind the head unit, but I think those are Japan-only or SE Asia-only. As for the beeps, most/all models send the beeps through the dash speaker on the driver's side. If you really, really, really wanted to silence the alerts, what you would do is either cut the wires connecting the Telematics Transceiver to the Junction Controller that handles all the front speakers(6 speaker cars), or rewire the feeds from the amp to go directly to the front dash speaker instead of going through the Telematics Transceiver first(8 speaker cars with an amp under the driver's seat). Just note that this will prevent you from getting ANY audio notifications from the car.
    The easiest thing to get at would be the Telematics Transceiver. You'd have to remove the center console as well as the big piece of trim that the LED strip and the climate controls are mounted into. The TT is just behind the climate controls. Once you get it free, you'd have access to the wiring right behind it. You'd either cut the wires that go to the front speaker(6 speaker cars) or cut two pairs of wires and connect them together to bypass the TT(8 speaker cars).
    I do not know if you'd also have to rig some resistors into the wiring to prevent the TT from realizing the wires had been cut and it throwing an error code.
    Do I think any of this would be worth it? No. But I'm doing a lot of stuff to my car that practically everyone else thinks isn't worth it, so who am I to judge? lol
  6. apm63
    apm63 New Member
    Netherlands
    2024 Prius Prime
    Business Edition
    When I drive 1 kilometer over the speed limit: PING, look at my navigationscreen: PING, look left or right at a junction: PING, look in the rearview mirror: PING...so ffing annoying! It could be a European thing only, as the burocrats here like to monitor and regulate everything their citizens do. Shortly there will be a blackbox in every new car here that registers every move you make, it's getting really Orwellian here.
  7. bisco
    50,801
    toyota has had a black box forever. what's worse is connected cars reporting driving behavior to insurance companies
  8. kenmce
    kenmce High Voltage Member
    1,543
    514
    NY
    You realize Toyota does that right now, right? That's what the telematics system is for.
    AndersOne likes this.
  9. apm63
    apm63 New Member
    Netherlands
    2024 Prius Prime
    Business Edition
    Yes I am aware of that, but per july this year it is mandatory by law for every new car I believe
  10. Trollbait
    12,228
    The alert is mandatory. Cars have been recording the data long before that.
  11. Zeromus
    468
    240
    Ottawa Canada
    2024 Prius Prime
    SE
    Are they reporting the data about you or are they reporting data in aggregate for prius drivers in general?
    Because, as far as I know here in Canada, they can't report individual data to the insurance companies at all, its not allowed. At most I can see the little drive pulse thing in the app where it tells me I'm a good little driver that doesn't brake, accelerate, or turn harshly. With the exception of when I'm cut off on a highway or when it thinks a roundabout going 25-30km/hr is me making a "turn"
  12. bisco
    50,801
    idk what toyota is doing. gm and others were reporting to lexis nexus and they were selling individual acceleration, braking and cornering stats to insurance companies without permission from owners. a class action suit brought it to a halt.
