Removed seats to clean and now airbag light blinking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Juan Ramirez, Jul 29, 2024.
Tags:
  1. Juan Ramirez
    Juan Ramirez Junior Member
    Fullerton, CA
    Removed my passenger seat (2015 Prius) yesterday to clean under it. After putting it back on, and of course connecting the three wiring harnesses, the airbag light is still blinking.
    I will say that one of the harnesses was much harder to remove than one would think it should be. I don’t think I broke anything but who knows.
    Anyway, is this normal? Do I need to perform some sort of reset procedure? What is the worst case scenario if I damaged something?
    Thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    11,557
    2,030
    Durham NC
    Check and redo the plugs Make sure that both ends of the plug seat and car side are well inserted into their plastic members that allow them to fit together male and female and so on sometimes those wires contend to push out while you're pushing them together so make sure you have a connection but generally there's no resetting of nothing If the car was off and you took the seat out did whatever you were doing under there on the floor vacuuming cleaning housekeeping and then when you're ready to put the seat back in you set the seat back in plug up the plug and start the bolts turn the car on it should never know that the seat was gone for an hour or two while you were doing whatever it has no idea It does now because there's a connection that's a miss I would think.
  3. ChapmanF
    16,949
    You can get the trouble codes from the airbag system using a scan tool if you have one, or this way if you don't:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    It makes sense, of course, to go back and recheck the connections you made, but even then it often helps to know what the ECU says isn't right, so you know what you're looking for even if when you recheck it you think it looks ok.
  4. Juan Ramirez
    Fullerton, CA
    Thanks
  5. Juan Ramirez
    Fullerton, CA
    I actually have the scan tool; will take a look when i get home; thanks
