Removing Road Tar
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Jan 14, 2006.
  1. Tideland Prius
    16,404
    Also, in addition to the wax on the black plastic in the other thread, how do I remove the tar? I've removed the actual gooey part but the residue is still on the paint.
  2. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    Well, when I used to do hot-tar roofing during my summers in college, we'd get a small gasoline container and a rag to clean those trucks...tar is a hydrocarbon, you'll need some organic solvents.
  3. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    I use gasoline, but you don't need to soak a cloth with it for it to be effective. I also rub lightly, only as strongly as necessary.
    Citrus-based solvents will also work, but not as quickly.
  4. BT Tech
    BT Tech New Member
    885
    South Florida
    Any petrolium distilate would work like WD-40.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    All I ever use to remove road tar is Coke. Works great.Take a look at this:
    http://www.sciforums.com/archive/index.php/t-5009.html
  6. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    I hope you're joking. While Coke will remove it, it is because it is a mild acid. I doubt that it is good for the clearcoat. A better choice is a more neutral pH solution like the numerous Bug and Tar Remover solvents you find in an auto parts store. You guys still remember we have auto parts stores, right? Just checking! ;)
  7. Tideland Prius
    16,404
    Thanks for the responses!
    Hmm... so which of the suggestions should I try first? lol
  8. Rocketeir
    Rocketeir New Member
    28
    Edgewater, Florida
    I picked up my 06 superwhite package 6 last night, so the users manulal is still fresh in my mind. It acutally says to use turpentine to remove tar.
    Regards,
    Steve
  9. seasalsa
    1,278
    Kent, WA
    Turpentine is great for tree sap but not very effective for road tar. There is no mention of turpentine in the 2004 Owners Manual.
  10. Rocketeir
    28
    Edgewater, Florida
    2006 Prius Users Manual page 380.
  11. imntacrook
    imntacrook New Member
    289
    On the Beach
    I had some nasty tar behind my wheels and on the rocker panels, I tried everything to get it off and by accident I rubbed some turpentine on it and it came off like majic - hope this helps
  12. Tideland Prius
    16,404
    Any other option beside turpentine? does it hurt the paint?
  13. Rocketeir
    28
    Edgewater, Florida
    I figure if the owners manual says to use it, it must be a pretty safe bet.
    Steve
  14. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Kerosene does a great job, but wash off with soap and water afterwards, that is for spot cleaning. One can also wash the whole car with a bucket of water and just a couple of ounces of kerosene. Again rinse off with soap and water. Some people say that kerosene is bad for the paint, but I have never noticed any problems.
  15. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I have found that naptha lighter fluid (e.g., Ronson) is great for removing road tar and all kinds of goo, like what's left when you remove a price sticker. Just a few drops on a white cloth or paper towel (depending on what you're cleaning, paper is abrasive) and the goo is gone.
    Be sure to leave the cloth/paper sitting out, when finished, so the naptha can evaporate. You don't want to toss it in the trash where it might self-ignite.
  16. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Pretty much any of the suggestions will take off the tar. They will also remove whatever wax/paint protection you might have had on that spot. Don't forget to rewax/Zaino/whatever that location after you are done.
    In my case, it would be tar remover, spot wash with soap & water, rinse, dry, Zaino. I wonder how the dealer-applied "paint protection" holds up to tar remover?
    - Tom
  17. Tideland Prius
    16,404
    okie dokie. I tried peanut butter to remove the road tar smudge and it worked! It just needs a bit more rubbing than the wax on the black plastic.
  18. andyman68
    andyman68 Member
    131
    Columbia Missouri
    Don't have a Prius yet, but I was washing the car this week and trying to remove tar. I like the peanut butter idea. The only problem is my dog would be licking it off the car!
    Andy
  19. andyman68
    andyman68 Member
    131
    Columbia Missouri
  20. darelldd
    6,057
    389
    Northern CA
    It won't!
    I personally use WD-40. Though it is cheaper to use kerosene (just about the same as WD-40), it may not be as available or convenient for some. All the others mentioned here work great as well. Just wash and rewax when you're done, and you're as good (or better!) than new.
