Removing the 12V Aux battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DHonzik, Aug 10, 2005.
  1. DHonzik
    DHonzik Junior Member
    70
    Oak Creek, Wisconsin
    Can anybody give me a step-by-step procedure in how to remove the 12v battery? How do you remove the red cap covering the positive terminal? I need to run two power cables to the battery from the black plastic tray that sits over the temp tire. Will a regular spade drill bit drill through plastic? I'll need to make a hole to run the cables to the battery.
  2. NuShrike
    NuShrike Active Member
    1,378
    You can pull the red-cap off with your hands. I got a bass unit in the tray powered off that aux-batt.
  3. removeum
    removeum Member
    407
    El Paso, TX
    8) DHonzik
