replace 200V battery?
Discussion in 'PriusChat Shop Forum' started by fishvail, Oct 5, 2010.
  1. fishvail
    fishvail New Member
    Perrysburg, OH
    I took my 2004 Prius in a couple of weeks ago to have the oil changed, etc. They said it needed a good alignment, which they did. After I got in the car, the bars on the pictured battery were PINK!!! Scared me to death! It
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    You will get Multiple waning lights and the technician will be able to see multiple 'codes' when the battery is finally weak. The engine will rev up a lot and the fan that cools the battery in the right rear of the cabin will be loud. Pink just means the engine has not recharged the battery lately, not that anything is wrong. When you do get ready for a HV Battery (not soon, I expect) consider Re_Involt.
    FAQ
    50,800
    how many miles on her?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Don't worry. Pink is within the acceptable discharge range for the battery. I'd be worried only if it suddenly became a regular occurrence under normal driving conditions.
    I've often seen the hybrid battery down in the pink after the car's been in the shop. The shop folks likely just let the car sit for a period of time in IG-ON.
  5. Recon
    Recon Junior Member
    Denton, Tx
    I'm trying to figure out how many miles I might expect to get before replacing the 200V battery on my 2008 Prius...anyone got ideas on that?
  6. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Miles are a poor indicator of when a battery might fail. Because Taxis go through a great many miles per day, one hears of 200,000+ mile batteries. if you only drive 12,000 miles a year, you are unlikely to do as well, as the battery will need to live through 16 winters. Both years and charge-discharge events are better indicators. Lets say 10 years is doable for 90% of batteries Your HV battery is 100 % under warranty to 100,000 miles or 8 years, whichever comes first.
