Replaced Head Gasket. Motor starts runs 10 seconds and does a hard stop.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Hickle, Nov 26, 2024.
  1. David Hickle
    David Hickle New Member
    Virginia
    Hi all just replaced a head gasket in a 2012. Car had been sitting about 9 months. The motor runs for a few seconds and turns off hard. I’m getting a P261c code. The pump is plugged in and I see no issues. Also getting a P3000 code but like I said car has been sitting. Thanks in advance for any advice.
  2. Mendel Leisk
    40,239
    Did you manage to get it started and running prior to the repair?
    Don't keep trying to "start" it; you'll run the hybrid battery down, compound your issues. "Starts and runs" is probably a misnomer, it's more likely just the hybrid battery trying to start it.
    Double-checked all your connections? For example, the PCV valve hose going into underside of intake manifold? That one's easy to miss, will stop the engine right away.
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    1,568
    607
    South Central PA, USA
    The ICE is trying to start, but it is not starting. What you hear for 10 seconds is the electric motor trying to start the ICE.
    What scan tool are you using. I don't think that you are reading all the trouble codes that have been triggered by the car.
  4. ASRDogman
    ASRDogman Senior Member
    7,011
    3,669
    Did you remove the disconnect on the hybrid battery? If so, did you replace it?
    Make sure you push it in, hard, flip the lever completely, then push to the right, hard.
    It seems to be very sensitive. I would say yes it's connected, because the battery is
    turning the engine over. If it was running before, Then it will run afterward, if you
    put everything back together. What about the PCV valve hose? That's a common and
    easy thing to miss.... I missed it the last time I cleaned my egr system. You'll have to remove
    the airfilter box to get to it.
    I suspect it's something simple.
    But....
    [SOLVED] P261C Code: Low Coolant Pump 'b' Control - Fix Now!
    P3000 – What Does It Mean and How To Fix It - OBD2PROS
    Make sure that you have EVERYTHING connected. Double and triple check.
    Disconnect and reconnect to make sure.
    #4 ASRDogman, Nov 26, 2024
  5. BiomedO1
    BiomedO1 Senior Member
    2,579
    1,388
    SacTown, Ca
    When you say "Hard Stop", after cranking and not firing. I'm assuming you mean that the motor stop cranking isn't normal. That sounds like a timing chain/setting issue. Hopefully you did the two full manual rotations and double check the timing marks during your assembly, to ensure your correctly timed and no valves were hitting the pistons. If you didn't and the timing is off, you just bent some valves - Start all over again....
    If your off by just a tooth, some cars will run, but they'll run like crap - chances of bending valves are still there, when the VVT starts adjusting...
  6. David Hickle
    Virginia
    I used a string with a slip knot to keep tension on the chain until the tensioner got all clicked into place. I have no reason to believe it jumped time. I unfortunately did not do the rotations.
  7. David Hickle
    Virginia
    I
    Just using a blue driver scan tool. It’s usually done good by me. There are a few stored codes but nothing but the ones mentioned above now.
  8. David Hickle
    Virginia
    No sir. I pulled the motor with the plan of replacing it with a JDM. But decided to replace head gasket and reinstall motor. As far as the Hybrid battery it’s completely dead. I have double checked all connections and have no reason to believe I missed anything.
  9. Brian1954
    1,568
    607
    The Blue Driver scan tool is not capable of reading all the trouble codes in your Prius. Normally, when you get a P3000 code, you will also get a hybrid system trouble code that is not being detected by your scan tool. Also, after the engine does not start, there are a few additional trouble codes that get triggered, which you are not seeing.
    Why do you think the hybrid battery is dead? If that were the case, the engine would not try to start.
    My recommendation is to purchase a scan tool that is capable of communicating with all the systems (ECUs) in the Prius. Read this thread: https://priuschat.com/index.php?posts/3290690
    The Autel AP200 is a good choice. It is on sale right now on Amazon for $55.20.
    #9 Brian1954, Nov 27, 2024
