Replacing a power source ECU - how to?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by benjita, Aug 6, 2011.
  1. benjita
    benjita Junior Member
    Fairfax, VA
    Can anyone give me some idea as to where the power source ECU is located and how difficult it may be to switch out? Is this something that a non- Toyota mechanic could replace?
    Thanks!
  2. Patrick Wong
    18,200
    6,490
    The power source control ECU is located near the combination meter. I don't think it is very hard to replace. However it would probably be better to seek out a mechanic who specializes in Toyota vehicles to do that work - since that individual is more likely to have access to the required Toyota technical information.
    I am wondering how you came to the conclusion that the power source control ECU needs to be changed.
  3. benjita
    Fairfax, VA
    A short from an audio input device connected to the rear of the radio caused the following things to stop working: MFD, clock, radio, side mirrors, power outlets. Toyota dealer thinks it is the Power ECU but want to charge $1200 to replace. I can pick up a used one for $150 but have no idea how to go about replacing it. Do you know if the Power ECU needs to be calibrated in anyway?
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    If you are lucky, it may be that this can be accessed by pulling out the far left air duct, then the bottom and top panels that surround the steering column. Worst case would be removing the combination meter, which requires much more dash disassembly. Of course, you will need to disconnect 12V power, i.e. the battery negative cable.
  5. Patrick Wong
    18,200
    6,490
    I suggest that you subscribe to techinfo.toyota.com so that you can download repair manual info about how to reach that ECU.
    The ECU does not need to be calibrated.
    Before you replace that ECU I recommend that you personally verify that all of the relevant fuses are sound using an ohmmeter (rather than relying on visual inspection.)
  6. Xaoh
    Xaoh New Member
    Ottawa
    2019 Prius Prime
    Has anyone posted on how to remove it I? Other than just telling people to go to a mechanic …
  7. ChapmanF
    16,951
  8. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
    Take the dash apart, lots of videos for that.
  9. Xaoh
    Xaoh New Member
    Ottawa
    2019 Prius Prime
    Yup god it thanks
