Replacing Headlights 2010, how many ballasts?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Strike67, Sep 19, 2010.
  1. Strike67
    Strike67 New Member
    43
    NY
    I
    Okay I know that my basic 2010 prius has two different housings for the high and low beams, therefore having two different bulbs. I want to change both the high and low beams to HID.
    So do I need a total of four ballasts? one for each light or is it plausible with two ballasts thus, sharing a ballast for both the high and low beams for each respective side.
    And if it is possible to splice the wires and run one side off of one ballast, is there a reduction of power when both the high and low beams are running? Is it noticeable?
    FYI I also plan on getting HID Fog lights. I hope everything fits inside the small hood.
    Where are some good Hid kits for the fog lights? and low and high beams?
    Thanks for Help in advance!
  2. Strike67
    Strike67 New Member
    43
    NY
    I
    yet another dilemma, i need housing for the fog lights right? so the HID kits from carhidkits.com only come with the hid light and the ballast correct? so i would have to purchase the prius chat stock fog light oem quality kit? then swap the halogen for the hid bulb and ballast ?
  3. Dmanpizza
    Dmanpizza 2010 IV Solar Roof & Navi
    57
    I do believe you would need 1 ballast for each bulb.
    I did buy the priuschat oem fog light kit and then swapped then
    added the hid bulbs and ballasts. They work great!
  4. Strike67
    Strike67 New Member
    43
    NY
    I
    another question does the stock prius come with auto leveling lights? cause it looks like it
  5. Strike67
    Strike67 New Member
    43
    NY
    I
    nvm, they don't auto level. I found that XexonDepot makes some pretty good HID kits.
    I was confused becasue the 2010 prius comes with projectors :)
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    The PriusV which has LED headlights has the same type of auto leveling that the Gen2 had for its HIDs. The sensor measures the distance between the rear axle beam and the body, it sends an input to a control module under the dash which sends a command to the leveling motors in the headlight assemblies. The low beam halogens and high beam LEDs are mounted in the same assembly so there is only one set of mechanical adjustments and one leveling motor per side.
  7. andino
    andino Senior Member
    746
    550
    San Jose, CA
    The Halogen headlights don't have an auto leveling motor. Only the V with LED headlights have that feature. And any other factory HID equipped car.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    (Regarding the bolded part) Huh? Not true. My 04 350Z and my former 02 Maxima had factory standard HIDs. Neither has any sort of auto nor manual leveling mechanism.
  9. tumbleweed
    4,067
    690
    Eastern Oregon
    I agree with the above posts, I have never heard of a halogen only headlight system that has auto leveling. I have owned two xenon (HID) equipped cars that have had auto leveling, Gen2 Prius and a Series 3 BMW.
    I think the very sharp cut off of the upper part of the beam may be the reason auto levelers are used. I have seen cars with improperly aimed xenon headlights coming toward me on a road with a lot of dips and rough spots. It sometimes looks like they are switching their lights from bright to dim every time the hit a bump or go over a little raise. The LEDs, although not as bright as good xenons, have the same sharp cut off of the beam.
  10. Strike67
    Strike67 New Member
    43
    NY
    I
    I ordered 6000k HID kit for my low beams from Xenon Depot, I heard from many forums that their quality is top notch.
    I changed my mind on HID Highbeams because the guy on the phone told me that unless I do alot of wilderness driving and need my HIbeams to be extremely bright that it was pointless. The reason being that HID setups have a warmup period of about a minute and most ppl just flash their highbeams to alert other drivers or to signal for something. Therefore halogens with 0 warmup period are the most practical for hi beams.
    That being said I'm looking for 6000k halogen bulbs for my highbeams. Does anyone know a good company?
  11. Strike67
    Strike67 New Member
    43
    NY
    I
    http://www.amazon.com/Putco-239006NB-Automotive-Lighting-Headlight/dp/B002R4V2VS/ref=sr_1_2?s=automotive&ie=UTF8&qid=1285115638&sr=1-2
    something of this sort
  12. Strike67
    Strike67 New Member
    43
    NY
    I
    I figure something like this is good?http://www.amazon.com/dp/product/B002R4V2VS?tag=priuschatcom-20
