Replacing inverter coolant pump -- anything cheaper but similar in quality to OEM?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cdherman, Apr 11, 2024.
  1. cdherman
    cdherman Junior Member
    31
    16
    Kansas City
    Like it says. The pump on Amazon is like $40, but a genuine one from Toyota is $150 or more.
    Rockauto has an AISIN for $90. Lots of parts AISIN makes are for the OEM market. (IIR, water pump I put on my Gen 3 Prius was)
    This is for my parent's 2008 Gen II prius. I own 2 Gen 3 as well, which might be in my signature line.
    Trying to do some serious maint at 140,000 miles before loaning the car to my brotherinlaw for a 5k trip through western USA.....
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You get what you pay for.
    Lots of fakes on Amazon. A race to the bottom from the PandaLand sellers/producers.
    Will it work ... probably. However, NOT for long.
    So was the $25-$40 knock off pump worth it?
    If you have to pay for labor, you will be paying twice.
    If the car has to get towed, major savings deficit.
    Stress and inconvenience has a price too.
    Just go OEM for $150, or save $60 and get the AISIN.
    OEM will give you proven reliability.
    AISIN, should give you great reliability too.
    $25-$40 Panda paperweight in the shape of an inverter pump, AVOID.
    Brian1954 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    11,552
    2,028
    Durham NC
    I'm not even using that type of pump as my inverter pump I've changed to something else but regardless I burn up several of the $40 jobs like within 30 to 90 days The factory ones that I'm taking out are always the originals generally speaking so there's always that so for a hundred and it's less than 150 bucks it's like 119 or something if you buy it online have it sent to the store etc so with these particular parts for these particular vehicles I would tend to say by the original you're going to generally get the same life out of it now if you're going to be out of the car in 3 years well packed accordingly I guess We are not so we generally try to get the robust pieces where they're needed so we can forget about those and worry about other things.
  4. Aloe
    Aloe Junior Member
    59
    Canada South
    Good find, I think the Aisin is the same as the OEM. The markings on the pictures are exactly the same, that white "o" marks. I'd go with it. It is missing the base, hence you just need to reuse your base plate and put those 3 new rubber dampers on as well, plus it's missing the invertor drain plug washer, so that's why it's a little cheaper. Also be mindful 3rd parties are not very reliable, the OEM is better but not great either. I had to replace one in under 33K miles and I believe the previous owner replaced it once before as it didn't have the original black base. So twice under 33k miles. Mine is still at 33K miles to date.
    #4 Aloe, Apr 11, 2024
  5. cdherman
    31
    16
    Kansas City
    0400032528 - OEM NEW Engine Water Pump w/ Gasket 1.5L 2004-2009 Toyota Prius - Nucar Toyota of North Attleboro
    So I found that part from a Toyota dealer. Good price at under $90. What arrived is certainly the correct part, with the washer even. But could it be an older version? Its a toyota part, looks like in the picture.
    If its correct, its a good deal. What arrived was NOT an engine water pump.
    For instance, they also have this part:
    G9020-47031 - Motor Assembly - 2004-2009 Toyota Prius | Nucar Toyota of North Attleboro
    Different part numbers, very different price. LOOK identical.
  6. Tombukt2
    11,552
    2,028
    Durham NC
    They're stupidity seemingly is your game they're both the same part in the same picture I take my pump off the bracket and leave the bracket in the car so I don't have to undo the bolt and the stud and that holds that other little bracket so you just bolting the black plastic pump to the existing bracket in your car and you can use the new three bolts if you like $85 that's a smoking deal for the factory original pump there's a lot of pumps you can put in place of the factory original but at $85 why would you even fool with that generally you wouldn't you would just replace the pump and be done for 10 years most people are going to be out of their generation too in the next three to five years more than likely they will age out or peer pressure will force them out whichever
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,921
    1,887
    NJ-USA
    Yep, AFAIK the pricier part was updated. The cheaper part was the "original" that failed more often.
    I got the $140 one 60k ago and have had no troubles.
  8. cdherman
    31
    16
    Kansas City
    Well, if you are right, its a sh**ty move from Toyota to still produce/sell the original defective part. Anyone else agree I got a crappy old part? Irony is that I read there was a recall for this problem in 2007. Maybe the 2008 that I am working on already has a better pump than the one I just purchased new.........
  9. cdherman
    31
    16
    Kansas City
    G9020-47031 vs 04000-32528 | PriusChat
    Found this old thread right here.
    My 04000-32528 part has the silver base. With an "O" on the upper hose nozzle. (which appears to be the same as the AISIN part as well, incidentally) And the aluminum seal (a washer for the drain plug) taped to the underside of the opening flap of the box.
    Hmmm....
    Label at the bottom also shows "Made in Japan 23"
    Hmmm....
  10. cdherman
    31
    16
    Kansas City
    Here is a screenshot from the recall documents:
    I wonder whether the 04000-32528 is kind of a hidden part number to get a toyota dealer doing a recall a special price. Average mechanic wants the G9020-47031 part and pays ~ $150. Toyota dealer follows the recall data sheet, orders 04000-32528 and gets a better price.
    Hmmmm...
  11. Kashmir
    Kashmir Junior Member
    Phoenix, AZ
    A few years ago I installed one of the $40 ones which I purchased from Ebay. Lasted 10 months. Learning my lesson I purchased an OEM one from the local Toyota dealer and I've had no issues 3 years later. Buy cheap, buy twice was my experience
  12. ChapmanF
    16,941
    04000- part numbers are 'kit' numbers: they bundle some part with some other stuff you'll probably be needing along with it, like a gasket or three. And often enough they are priced lower than the part by itself, just because of logistics of shipping and warehousing, and which they move more of.
    They're not, of course, only available to dealers; they are mentioned in publicly-available TSBs, and orderable at a parts counter near you.
  13. cdherman
    31
    16
    Kansas City
    Good to know. Hope other users will look for the 0400 kit. It was cheaper and had a washer for the drain plug to boot. I am now pretty sure my new HV pump is good to go.
