Replacing Rear Wiper
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tobalt, Dec 6, 2004.
  1. Tobalt
    Tobalt New Member
    47
    Huntsville, AL
    Ok, looks like my rear wiper needs replacement. Went for an oil change 3 weeks ago and asked them to replace all the wipers. They only did the front 2. Rather than go back and have to wait a while for 1 replacement, I thought about buying a retail one, and doing it myself. Only question is: this is my first car, and never had to deal with replacing a wiper. I need info on the correct side for the replacement, as well as any recommended brands.
  2. removeum
    removeum Member
    407
    El Paso, TX
    8) All you will need to replace is the wiper insert. There is a little plastic cap shaped like a U. Gently pull open and lift up. Then take a socket remove the arm and blade unit. Pull out the old blade use the two metal rods and reinstall blade to the unit.
    Ben
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Do you REALLY need to replace those wipers already?? I hardly ever use my wipers anyway b/c I use Rain-X.
  4. removeum
    removeum Member
    407
    El Paso, TX
    8) Doc.
    I use Aquapel on the front windshield and just put on winter blades from Auto Zone.
    Ben
  5. Tideland Prius
    16,401
    Quick question. The lower rear window is nice when it rains and it stays dry and clear (until you stop) but it also gets dirty since it's basically the rear of the car and thus is useless when it's covered in dust or just tiny water droplets that can't be removed since the spoiler blocks and wind turbulence. This means that I have to constant clean the rear lower window. I wonder if they should have window washers on the lower rear windows? Not just for the Prius but for other vehicles that have this design like the C-Class "coupe", MX-7, Insight etc
  6. Batavier
    Batavier Member
    442
    The Netherlands
  7. efusco
    19,891
    1,194
    Nixa, MO
    So, Ben, why Aquapel? Is it better/different than Rain-X? Talk to me....
  8. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    I had the same issue with my Odyssey. Unless I told them all THREE refills, they only did the front 2. Don't know why. Also, make sure you say REFILLS because sometimes "replace the wipers" seems to mean the rubber AND its support. You generally shouldn't ever need the support part replaced. Much more expensive. The only common time would be if you use winter wipers. Then you have to get the whole thing as it is encased in a rubber shield so ice doesn't build up in the pivoting parts.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I simply need something to soften up the rubber, it squeals across my back window on the first pass and only wipes a decent path on the return stroke. The fronts still wipe pretty well.
    Does such a substance exist, or is it easier to replace the blade?
  10. Tideland Prius
    16,401
    Ah bon, la nouvelle C4. I guess that's one way of solving it lol.
  11. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    You can "renew" the edge of most blades simply by carefully washing them to remove the buildup of crud. A couple of end-to-end wipes with a soapy sponge and then drying them with a paper towel. You'll notice a lot of black on the towel when finished, and you'll also notice that the edges are rough when you begin and get smoother as you finish.
  12. removeum
    removeum Member
    407
    El Paso, TX
    Well from what I have read, what I have seen how well it works on my government vehicles and now on my POV's it is a lot better than rain-x. It lasts longer than rain-x with one application which is good for approx. six months.
    I have yet to find ice on the the windshield yet as well.
    Ben
