Reset on Consumption Screen?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tassee, Aug 16, 2008.
  1. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Hello, I'm a very new 2008 Prius owner just having my car about 4 weeks. I had about 463 miles showing on the consumption screen with an average of 47.5 mpg. My total miles however was 853. After I went shoppping and got back into the car, I turned it on and the stats were gone! There was nothing showing it was like it started over again. I went to my service dealer and they told me that it was nothing, I had probably reset it. I told them I never did because I wanted to check out how my average mpgs were going to be. Any suggestions? Please someone, can you advise if something is actually wrong? Thanks, Marcia
  2. WayneF
    WayneF Junior Member
    Marcia, the "miles" on the LCD does reset automatically to zero every time you refill the tank with gasoline (it may take a few seconds, but the miles is reset).
    The cumulative MPG on that screen does not reset until you reset it. But it is possible to accidentally press the reset button when cleaning the window.
  3. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    There was a lady a month or so ago who took her kids to the ice cream store and it reset on her also. We suggested she accidentally reset it, or somebody put gas in the tank and it didn't register until she drove it, but maybe there's something else. The car was cool, left it in the sun for awhile, and the gauge reset, kinda like your situation.
    In any case, it's probably not too serious. You'll accidentally hit that reset button at some point anyway, so it's best to write down each tank (and maybe put it in an excel spreadsheet for tracking trends like us OCD engineers do).
  4. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Thanks for the info, but I know that I didn't hit that reset button. I'm also concerned due to the large volume of complaints about the Prius in the winter. I live in PA and alot of the roads are hilly and twisty turny. Am I going to have a problem? Also, I bought an extended warranty for the car but yet, when I spoke to the service dept. they say if I brought it in and nothing was wrong they were going to charge me? Does Toyota service departments charge for that? Any help would be most appreciated. Thanks again, Marcia
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Dealers and service departments are independently owned, as required by U.S. law. The policies of the service department will be their own, although you can bring some pressure to bear by complaining to Toyota corporate.
    It sounds to me like you are borrowing trouble. The Prius does just fine in the winter, especially if you put decent tires on it. As for the consumption screen, there are several possible ways the system could reset. Most are unlikely unless you have a low 12V battery. While you will deny it, the odds are very good that you or someone else reset the screen, either on purpose or by accident. That is almost always the case.
    Tom
  6. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Tom, thank you so much for your reply, but I know that I didn't hit that reset button. I was in awe of how much mileage I was getting at 47.5 that I wouldn't have hit that button because I wanted to gauge myself. I drive that my by myself and no one else drives it but me. I'm just a tad bit nervous reading all the posts where people are dissatisfied with their vehicle. I bought this vehicle because I drive a substantial amount of miles to work each day and then run around on the weekends doing errands. I was driving a 2007 Jeep Laredo which gave me about 15 mpgs so in that respect I do love my Prius. As I said, just a tad nervous due to the hilly nature of Pennsylvania and the amount of hills I navigate each day. You did mention good tires. Do I need to buy snow tires (4) of them for the winter? Thanks again, Marcia
  7. qbee42
    18,058
    3,076
    Northern Michigan
    Complaints work like that. People who are happy go about their days doing other things, and are generally too busy to bother with positive, glowing comments. Unhappy people, on the other hand, want to complain. That's true in general, and true with the Prius. For each complaint you read, there are a thousand good stories that never get posted. Take the complaints with a grain of salt.
    In an area with real winter driving, I would use real snow or ice tires. Jayman can tell you about that with his 2004 Prius. For most of the U.S. you can get by without dedicated snow tires. I use Micheline MXV4+ Energy all-season tires and get around just fine, and I'll wager that our Michigan winters are as bad or worse than yours. The OEM Goodyear Integrity tires have very poor traction characteristics, so they don't do well in rain and snow. Some people have posted about using the OEM tires in adverse conditions and think they are fine, but I didn't like them. I swapped mine before the first winter. If I had it to do over again I would have swapped them at the dealership.
    There are many threads on PC about winter tires. Most Prius drivers are looking for a good tire that doesn't hurt their mileage. Micheline and Nokian are favorites. Get a cup of coffee, search for tires, and spend some time reading. Google is better for searching than the built-in search function. Try this line in your goole search: tires site:priuschat.com to limit the search to PC.
    Tom
  8. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Tom, should I be having then two sets of tires, winter and regular? Also what about inflation of the tires ... should it be more than the recommended? Went out and looked at my tires 185 65R15. Those tires you mentioned do not comein my size. Any other tires that are just as good? Marcia
  9. qbee42
    18,058
    3,076
    Northern Michigan
    I wouldn't bother with two sets, but that is a personal decision. One set of all-season tires should work where you live.
    The MXV4+ Energy tires are no longer offered in the stock size for the Prius. The have been replaced by the MXV4+ Primacy tire, which is similar but not identical. The Primacy is supposed to work a little better on snow. Many PC members also report good results with the Nokian WR G2 tire, but I haven't tried them. Either are a good choice.
    Tom
  10. Patrick Wong
    18,200
    6,490
    Hi Marcia,
    This is a normal policy. The dealership cannot charge Toyota if a customer has a "no trouble found" issue, so the customer is put on notice that s/he will be charged instead. The policy discourages "frivolous" complaints, which is good from the dealer service dept's perspective.
    Regarding your concern about Prius performance in the winter, I suggest you upgrade your tires before the snow season starts, as Goodyear Integrity tires do not enjoy a good reputation for snow traction. Nokian is a popular brand with owners who must drive in snow.
  11. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    OKay, thanks, I did research the tires and will probably swap them out before the winter comes. Now for my other question about the gas tank. When I was down to 3 lines, I filled up and it took 8.46 gallons. The next time I filled up I only had 1 line left and it only took 8.66 gallons. I read my book and I said I had an 11.9 gallon tank. Am I missing something here? Thanks, Marcia
  12. rayxoxo
    rayxoxo New Member
    39
    Sacramento
    Hello Marcia;
    Your Prius has a bladder tank. I am no expert on it's function but have read somewhere that it changes shape for climate changes. I thought it was rather weird but what isn't with the Pruis??? lol
    Ray
    2008 Prius pkg 6
    Sacramento, Ca
    formerly borned and raised in Pgh...
  13. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Re: Bladder?
    OKay, now I'm stumped... What the heck is a bladder tank? Don't I have a normal gas tank in the 08? I thought it was kinda weird that on one line I filled up with 8.66 and with three lines 8.34 or thereabouts? HOw do I really know how much gas is left in my tank. Let me tell you, my roads are dark and dreary when I go to work at 5:00 am and there's nothing around but the woods and trees. Kinda gets me a little bit nervous??? Marcia
  14. Patrick Wong
    18,200
    6,490
    Hi Marcia,
    The North American Prius has a flexible bladder within the fuel tank. The purpose of this bladder is to reduce hydrocarbon emissions into the atmosphere.
    The gas gauge, as you've discovered, does not provide an accurate reading of remaining fuel. Hence many owners justifiably refer to it as the "guess" gauge. The practical result of having a bladder-equipped fuel tank and the "guess" gauge is that you do not know the exact capacity of the fuel tank, nor can you easily determine how much fuel is left.
    11.9 gallons is a nominal rating. The actual capacity depends upon ambient temperature, when the gasoline pump being used decides to cut off, and how aggressive you are in continuing to pump gas beyond that point.
    You ask how much fuel is left in the tank. If you've pumped 8.66 gallons, then the fuel tank should contain at least that much fuel (if you assume that the gasoline pump used is honest.)
    If you reset the MFD after refueling, you can use that display to show miles driven and average mpg for the tank. This allows you to calculate how many gallons have been consumed. Subtract that from the 8.66 gallons pumped to determine a conservative estimate of remaining fuel. Also compare to the fuel gauge reading. To avoid running out of gas, refuel when you have a couple of gallons remaining in the tank, or when the fuel gauge shows two bars; whichever comes first.
  15. Tassee
    Tassee New Member
    27
    Pittsburgh, PA
    Wow, that kinda explains why with one bar left the tank only took about 8 gallons and with 3 bars left it only took about 8 gallons. I wonder why no one at the dealership bothers to let you know these things. No one told me really anything about it at all. I do love the car however, I'm averaging about 47.7 mpg with hills and then valleys. There are alot of horror stories here though about the car. Don't want to sound stupid but MFD? What is that? Marcia
  16. jimsoh
    jimsoh New Member
    30
    west central Ohio
    Multi Functional Display MFD .
    You better search & print a list of acromnyms, if you want to utilize this site and the very valuable info shared here. These guys are into acronyms.
  17. qbee42
    18,058
    3,076
    Northern Michigan
    MFD is the Multi Function Display, or the little computer screen in the middle of the dash.
    No one at the dealership lets you know these things because most car salesmen are clueless.
    Stop worrying about the horror stories. I can repeat my previous post if you want, but it's easier to recognize that the Prius is presently the most reliable car you can buy. Don't worry, be happy...
    Tom
  18. patsparks
    10,664
    567
    Adelaide South Australia
    Marcia, congratulation on purchasing a fantastic car. You have made a good choice and the odds of a trouble free life together exceed those of any other car on the market, not just in my opinion but the opinion of most Prius owners.
    I'm not sure why your consumption reset but for the purpose of tracking consumption I suggest you keep a record in a small note book of consumption for each tank. I suggest you record the fuel added against the distance travelled and also the average miles per gallon as displayed on the centre screen. Reset the screen on each fill and you will be able to more easily track improvements or if the prevailing conditions or the way you are driving this tank are having a negative affect on consumption. Keeping a lifetime average on the screen will mean you get an ever slowing response to changes because of the higher miles and gallons of fuel you are averaging.
    I hope that makes sense.
  19. qbee42
    18,058
    3,076
    Northern Michigan
    MFD - Multi Function Display
    ICE - Internal Combustion Engine
    HSD - Hybrid Synergy Drive
    PSD - Power Split Device
    MG1 & MG2 - Motor Generator 1 & Motor Generator 2
    HV Battery - High voltage or traction battery
    Trac - Traction Control
    VSC - Vehicle Stability Control
    The list goes on. Search for acronyms.
    Tom
  20. Patrick Wong
    18,200
    6,490
    Hi Marcia,
    If you do a search for "out of gas" you'll find many stories from owners who had problems because they assumed that Prius behaves like their previously-owned vehicles. A recent PriusChat poll revealed that ~25% of respondents ran out of fuel at least once... Is that what you meant by "horror" stories?
    The dealer staff did not tell you about the gas gauge, either because they do not know, or because they are not eager to provide you with reasons why not to buy the Prius.
    If by "horror" stories you mean various reliability issues, note that PriusChat is a very active forum, so over time you'll be exposed to whatever problems exist. However, the % of owners with a given problem remains quite low. Hence Consumer Reports continues to report very high Prius owner satisfaction and loyalty.
