Resurrecting stored Gen I Prius
Discussion in 'Generation 1 Prius Discussion' started by lapp, Sep 6, 2010.
  1. lapp
    lapp Junior Member
    I purchased a Gen I prius (non running) two years ago for a very low price and kept it in dry storage. At the time it threw a P3125 code on the ECROS scanner and would not start. (I have two Gen I since new that are our daily drivers).
    I finally have the non-running one in my own garage and am trying to get it running. The HV battery has been charged to 285 volts by a DC/DC converter I built. Last year the car would power up the ECROS OBD scanner and throw a P3125 code and I could hear the main HV Battery relay connect then disconnect. Now when trying to start it the 12 volt systems work, the OBD scanner from ECROS will not run, it has power, but no data - no OBD signal I guess, and no HV contactor noise either. I took the Vehicle ECU out from under the passenger carpet and replaced it with a good one from one of our daily drivers and still no OBD signal. I have checked all the fuses and no blown ones in any of the three fuse boxes. With the used Prius ECU in the daily driver, the OBD does work, the daily driver does not start, but no error codes.
    OK, what am I missing, why does the OBD II not fire up the ECROS scanner in the broken Prius?
    Thanks for any help.
    cheers
  2. lapp
    lapp Junior Member
    One more piece of information I forgot in the earlier post. I did take the car to Toyota a year ago and they pulled "C1259 – Malfunction in HV ECU" on their OBD, but as I said, nothing comes up now.
    Cheers
    Steve Lapp
  3. bwilson4web
    15,934
    Ok, so more details about charging the traction battery. Did you removed it and charge on a bench? You jumpered the middle pair so all modules were charged? Do you have a list of the module voltages with #1 being the one closest to the control electronics? The safety interlock is back in and closed?
    What is the 12 V. battery voltage with the key turned on and lights on?
    Are there two Prius now inert:
    (1) stored Prius
    (2) donor daily driver
    First we make sure the 12 V system is working and the under load voltage is in the 12 V range. Then we work the rest of the issues one-by-one. Again, you have just one or now two broken Prius?
  4. lapp
    lapp Junior Member
    Hi Bob:
    I was rushing to get the last post off, so yes, the trail of events was not clear. I hope this is better.
    To answer one question. My daily driver is still running fine after having tried the HV ECU in it, 210,000 kms and all is well. I even had a solar panel on it at one pint feeding into the main HV Battery, that was fun.
    I used a large good condiiton 12 volt battery to try the stored prius - so voltage was stable at about 12.7 at battery. All 12 volt devices (wipers, power steering assist, brake booster pump, radio, headlights, dash display screen) work when key is in run position. I did have to replace the main 100 amp 12 volt fuse in the engine compartment after a reverse polarity episode in a dark garage - and all 12 volt systems now work again. (could this have fired something else?)
    HV battery has not been out of car, and measures 285 volts while open circuit. Safety interlock is in. When I first had the stored Prius, I could hear the main contactor in the HV battery closing and then opening, but I do not hear that now when I turn key to start position. I have a history of building electric fuel cell powered cars, so am pretty good on that end of the machine (aside form the occasional reverse polarity - only did that once!).
    What perlexes me most is the lack of OBD signal to get any display on the Graham Davies ECROS tool. It works fine on my daily driver, but when connected to the stored prius (with Igniton on) the ECROS shuts down a few seconds after powering up - that prevents accessing any codes.
    OK, over to others for thoughts.
    Thanks
    steve lapp
  5. Patrick Wong
    18,200
    6,490
    Hi Steve,
    1) The inverter was a suspect part from the beginning, with DTC P3125. Given your one reverse polarity incident (one is all that is required), it is likely that the inverter is now definitely dead. Since you own multiple Prius you can swap the suspect part into a working vehicle to confirm whether this is the case.
    2) I suggest that you remove each 12V fuse, one at a time, and check continuity with an ohmmeter. Do not rely upon visual inspection. By the way, does your dome light in the passenger cabin work? That would show whether the DOME fuse is good. That fuse provides keep alive 12V voltage to several ECUs.
    3) Since you don't have activity on the OBD-II bus, you might swap the various ECUs into a working vehicle to see whether you can find a bad part. Apparently at least one ECU is inhibiting communications on that bus (engine, hybrid vehicle, traction battery, skid control are the major ECUs).
    4) DTC C1259 is logged by the skid control ECU and indicates the hybrid vehicle ECU has a regen malfunction problem. However the root problem might be elsewhere, perhaps the transaxle for example. Other DTC would be needed to narrow that down.
    5) I recall that the hybrid vehicle ECU and immobilizer ECU need to be initialized to recognize each other as part of the vehicle security system. So when you swap the HV ECU you'll need to perform that process. Suggest you obtain repair manual info at techinfo.toyota.com
    6) To the extent that you are swapping parts as a diagnostic process, I recommend that you move parts from the failed Prius into a working Prius, one at a time, rather than the reverse. Then see if the working Prius still works. The reverse practice will only work if the failed Prius only has one failed part. In your case it is highly likely that the failed Prius has multiple problems.
  6. bwilson4web
    15,934
    Ok, now this makes a lot of sense. Fortunately, vincent, w2co and I have been working in the OBD area. Here are some suggestions:
    That the Graham scanner comes up briefly means the ground, pins 4, 5, and battery voltage, pin 16, are OK. However, the Prius uses ISO-9141, verified with Auto Enginuity and a pig-tail which opens up questions about:
    • K-line, pin 7 - should float high at ~12 V with a 510 ohm pull-up resistor to B+
    • L-line, pin 15 - a line that should be pulled up by the scanner to indicate it is connected.
    If you measure the K-line with the 510 ohm pull-up resistor and it shows ground, this suggests one or more of the seven ECUs is holding it low. Furthermore, all scanners need to go through an initialization sequence, often at 5 baud. If a pull-up resistor does not bring the K or L lines up to 12 V., I would suggest finding the OBD junction connectors and isolating the different ECUs until the pull-up resistor brings them up to 12 V:
    • J22
    • J23
    • J16
    Using "Electrical Wiring Diagram", EWD493U, in "2 Prius" diagram in the back under column 5 and 6, under "M OVERALL ELECTRICAL WIRING DIAGRAM."
    You might also consider using the Tc, pin 13, and Ts, pin 14, to see if touching Tc to ground causes any codes to flash. You'll have to identify where the flash indicators are located and the manual indicates some ECUs require a LED with current limiting resistor. This is an alternate to the ISO-9141 signals and verifies the connected ECUs are responding.
    My thinking is we need to fault isolate the ISO-9141 K and L-lines as well as using Tc/Ts, an independent diagnostic bus system, to check each ECU.
  7. lapp
    lapp Junior Member
    Hello Patrick and Bob:
    Excellent suggestions. Yes, it seems an ECU is kaput, and yes, moving them to the working Prius is the way to check them. The dome light does work. It may be a few days before I get time to mess with swapping ECUS. Once OBDII output is available, I will go to next level.
    Thanks
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    if you swap HV ECU's, you will most likely have to reset the immobilizer.
    Best procedure is:
    1) hook a small 12v charger to the 12v battery to keep it topped up.
    2) turn ignition to ON position (not start)
    3) wait 30 minutes
    4) turn key off, then to on/start
  9. bwilson4web
    15,934
    I had just recently introduced a new key and keyfob to my NHW11 but I'm wondering which 'learns' the key ID and fob ID? Is it the immobilizer that learns the IDs?
    Thanks,
