reversing/back up[?] lights
Discussion in 'Gen 2 Prius Main Forum' started by benway, Dec 22, 2008.
  1. benway
    benway New Member
    I have searched here but cant find much info on this. [maybe I am using the wrong term, in the UK thay are called reversing lights:D]
    what is the general consensus about how well the the reversing lights function? do people find they are bright enough?
    it is getting very dark in the morning here now, and they dont seem to be throwing that much light.
    I have read that an LED "upgrade" doesnt work so well because the reflector is not designed for the LED light pattern?
    thoughts/ comments much appreciated
    thanks
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Mine work fine. I use the backup camera, and it is very light sensitive. When combined with the backup (reversing) lights, I can see in back very well.
    Tom
  3. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    The stock backup lights are ineffectual. (Unless you have a backup camera)
    No.
    Backup lights don't need a precise pattern. The problem with a LED upgrade is that there is no good way to get in there to stuff it with LEDs. I'm not familiar with an LED bulb that it skinny enough to fit in the hole and powerful enough to want.
    I've been looking over the back of my car and am having trouble finding a good place where I can install lights. I've considered:
    Make holes in bumper cover, seat them in there.
    Hang under bumper.
    mount some kind of stock light on top of bumper
    lights glued up against rear window from inside.
    LED strip light running along bumper or hatch cover.
    Still don't know what I'm going to do.
    Quote from Tom_06:
    One easy approach is to tweak the lamps. You might consider the Raybrig R132 lamps from Sigma. They are 27W, where I think the originals are 24W so I don't expect much of a problem from increased heat. It's not like you drive around with them on all the time. See http://www.sigmaauto.com/jdm/prius/prius0405.php and look along the right hand edge about 1/2 way down.
  4. benway
    benway New Member
    thanks for the replies
