Rough Start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anxious, Dec 21, 2009.
  1. anxious
    anxious Junior Member
    Long Island, NY
    I started my 2010 today after 3 days of it resting in the garage.
    I was frightened since the engine was quite rough and loud, almost
    sounding like metal was hitting something. After about 45 seconds it
    sounded smoothed out. Before I go to the dealer....is this normal in the cold climate. PS I'm only in Long Island .....not Canada!
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Obviously almost impossible to evaluate without actually hearing it. My advice would be that since you have a brand new automobile, under warranty, which has synthetic oil in it, if I was at all concerned about how it sounds on start up, I'd just take it to the dealer. I don't think it should be "quite rough and loud" nor should there be a sound like metal hitting something. So your best bet whether it turns out to be nothing or something is to get it to a dealer and document your concern. In the case of something that might be engine related I'd want my concerns documented ASAP. If it's an intermittent problem it might be hard to track down, and/or it might be something that get's worse with time. As far as warranty goes, the sooner you bring this to light with Toyota and your dealership the better. Document your concerns and what is done towards resolution.
    Good luck, hopefully it is nothing.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Fairly common, here is one of two or three threads that talk about this problem:
    http://priuschat.com/forums/gen-iii...troubleshooting/70128-rough-engine-start.html
    No resolution or comments from Toyota as far as I know. I've had the problem two or three times but not for a couple of months now, maybe it gets better as the car the car gets more miles on it?
    Edit: I think Electric's suggestion of taking it in and having it documented is a good idea. Don't be surprised if Toyota says "Oh! we have never heard of this before." even though they have, quite a few times.
  4. Jasonsprite
    Jasonsprite Junior Member
    74
    Northridge(Los Angeles),Ca
    2019 Prius Prime
    Welcome to the club.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I have read several posts here concerning the rough start, beginning with Bob Wilson's post.
    I have made a couple of short starts and stops without any issue. Then the other night I started the car and moved it from the driveway to the garage. I turned the car off with the engine still running during a warmup cycle.
    When I went to start it the next morning, mine did exactly what you described for a few seconds until I put it in drive. It settled right down and I have not had any issues since.
    I am mighty thankful to the people here at PC for having posted on this issue. If I heard this without the knowledge of these posts, I would be very concerned also because it is a very disturbing sound.
  6. ABL
    ABL Member
    163
    30
    San Jose Ca.
    Same thing happened to me about 1 month ago (1 time only) My Prius iii has approx 2600 miles and sounded like a busted washing machine. Havent had any further problems.
    Jim
  7. Frankblack0503
    Frankblack0503 New Member
    64
    Belgium
    Had it yesterday after the car was 4 days in my garage...Can't the prius handle a couple of days standing still in a garage ?
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Have also had it (see other post). Does it depend on how the car starts? Mine had been sat for over a day and it was about -4 c during that time. When I got it I put it in 'ready' mode and before the engine started I switched on the rear heated window. The engine fired up as soon as I did this and that's when it sounded rough. A broken washing machine is a good description.
    Is it a software problem? If I had left the engine to fire up as normal after 10 seconds would it have been ok? The HV battery was showing nearly a full charge. Did I cause the problem by switching on a high load with the rear heated window?
    Anyone else find they had similar or is this just a coincidence?
  9. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
