Routine Maintenance Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TucsonPrius, Apr 11, 2004.
  1. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    I'm planning on performing the 5k services myself to avoid the Toyota $60 (that's their discount price) oil change/tire rotation and have two questions:
    1) what size are the lugnuts for the wheels? (I'll need a socket to torque them to the specified 76 ft-lbs)
    2) what bolts are re-torqued on the chassis? (The service "passport" mentions this.)
    Thanks,
    Shawn
  2. Raenstoirm
    Raenstoirm New Member
    179
    Maryland
    I have another question in this department...does anyone have a list of toyota's reccomended maintenance schedule? What they are actaully doing and how much they charge for it?
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    a 13/16" socket fits the lug nuts. If your going to buy one get a 6 point to avoid damage to the chrome lug nuts. As for the rest of the nuts and bolts on a Toyota you'll need the following sockets and wrenches, 10, 12, 14, and 17MM those are the ones most used on Toyota products. Almost all the threads are 1.25 thread pitch if you need replacement fasteners. Have fun.
  4. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    13/16" Huh? I would have thought Toyota would have been metric all around. Go figure!
    Thanks for the quick reply,
    Shawn
  5. Frank Hudon
    4,147
    after about 3/4" there are SAE's that fit some not well but in a pinch, I'd say if your going to do your own maintanance go and buy a set of metric wrenches and sockets. It'll pay in the long run. If you don't loose them good ones last a life time.
  6. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    I just checked, a 13/16" socket does *not* fit. Almost, but not quite. Must be a 21mm (which I don't happen to have). Can anyone confirm?
    Thanks,
    Shawn
  7. Frank Hudon
    4,147
    Sorry Shawn but I just checked my Prius and it fits. Go figure on that one. Just took a measuement and it's 13/16 which is 21mm. Sorry.
  8. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    Thanks for taking the time to check.
    That leads me to believe it is really a 21mm (13/16" = 20.6+mm). That extra .4-mm must be the reason, I can't fit a 13/16" and you can (diferent tolerences in the the socket/lugs?)
    Thanks again,
    Shawn
  9. Frank Hudon
    4,147
    now you peaked my interest in this problem. Went and got all my 13/16" sockets (3) and tried them all and the only one that had a tight fit was a Craftsman all the rest were fine I manage to get the Craftsman one on but it was really snug and probably scratched the chrome on the nut, but I wanted to see if it really would go on and it did. Still sorry for the bum stear on that one.
  10. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    Funny, the socket I can't get on is a Craftsman, too (12 point).
  11. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    You can find the answers for all of your questions -- except for the $$ they charge (I suspect it depends on the dealership) -- here. It's the 2004 Prius Maintenance Guide.
    If someone would like to price this, I'd be interested, because I'm considering the PrePaid Maintenance package from Toyota (as discussed in this thread.)
  12. autoxic
    autoxic Commuter
    111
    Richmond, VA
    I think the lug nuts are 21mm, as they are on my 2001 Celica. My basic X lug wrench seems to work, but you can always use the lug wrench near the spare tire.
    You should torque your wheels when putting them back on the car. To do so, you may need a short socket extension in addition to a 21mm 6-point socket. This will help the torque wrench clear the edge of the wheels. Torquing the wheels helps prevent brake rotor warping.
  13. jchu
    jchu New Member
    1,063
    Nampa, ID
    Would confirm that 21 mm is what it is
  14. Gen2
    Gen2 Member
    319
  15. Frank Hudon
    4,147
    they are also available in teflon lined for protection. Mac or Snap-on carries them. Also available at some of the better part houses.
  16. rocketman7
    rocketman7 Junior Member
    73
    Central Coast California
    With regards to the prepaid maintenance package - I talked with my dealer's service department today and the guy said that it was unusual for someone to have purchased the prepaid package from someone else and use it there. In fact, he said that two local area dealers didn't honor the prepaid package sold from other dealers. This sounds a little funny to me - does anyone have any experience with this?
  17. Brian
    Brian Member
    480
    Bakersfield
    I think that the DEALER that sells it is paying for the coverage and another dealer might not want to cover it because they arn't paided by the other dealer.
  18. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(TucsonPrius @ Apr 11 2004, 10:18 PM) [snapback]11042[/snapback]</div>
    FWIW, I just rotated my tires at 12,492 miles and my Craftsman 12-point 13/16" regular socket (1/2" drive) worked perfectly when torqueing the lugnuts to 76 ft-lbs. A 3" extension cleared the fenders.
    Of course, that particular socket is 30 years old (from my original toolset made back in the days when the name 'Craftsman' meant something) so that might have had something to do with it, too.
    Someone mentioned that torqueing the lugnuts helps prevent brake rotor warping. It's not a bad idea to perform the tightening with the wheel/tire off the ground, as well. It's not a big deal but it would seem to more more evenly distribute the torque than if the wheel were tightened while on the ground.
  19. mikel 52
    mikel 52 Member
    128
    2002 Prius
    I checked the size of my lugnuts the other day. I'm due to rotate my tires and checked to make sure I have a socket that fits. my 13/16" fit pretty good, just a tiny bit loose, so I tried a 21mm and it was really loose.
    Mike
  20. rudiger
    696
    45
    Cincinnati, OH
    <div class='quotetop'>QUOTE(mikel 52 @ Oct 13 2006, 02:04 PM) [snapback]332373[/snapback]</div>
    I found the same thing (although I wouldn't say that the 21mm was 'really' loose, just 'more' loose than the 13/16"). Evidently, there is enough specification variance in the size of the lugnuts/sockets that either a 13/16" or a 21mm socket can be the preferred choice.
    This is why it would be prudent to check prior to actually performing the task if the supplied lug wrench is going to be used to loosen the lugnuts, then a torque wrench/socket is used to tighten them.
