rust under the bonnet
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ekkert, May 30, 2010.
  1. Ekkert
    Ekkert New Member
    London
    Hi guys thanks for all the info you post here - amazing forum!
    I'm considering to buy a Prius (2nd Gen, most prob. year 2008).
    Was looking at couple examples yesterday - both 2008, around 30,000 miles. What I noticed, was some rust under the bonnet, as well as on the bonnet hook. Also, the battery had some sort of salt/calcium layer on the side. And what quite surprised me is how "open" some wires and connections are, while some where just covered in electrical tape. Is this normal?
    Sorry for possibly stupid questions - these where the first Priuses I've ever looked at under the bonnet.
    Can you please take a look? Thanks loads!
    Random rust points:
    "Open" wires. The windshield washer fluid cap was also missing :) :
    Bonnet hook:
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Sorry, I don't really have an answer for you. I've only looked at new Prius. That corrosion around the bolts is really strange. That level of specific corrosion on a 2 year old vehicle would make me nervous. My 1993 Accord didn't have that level of corrosion and it had 17+ years of exposure to the elements...in the Pacific NW...not the dryest region in the land.
  3. Bob64
    1,540
    93
    Virginia
    Hmm, well, I have a bit of rust, but it doesn't seem as bad as the above pictures. I can confirm that pictures 2 and 4 look similar to my car.
    Mine also has electrical tape on the ends of the wire looms.
  4. richard schumacher
    7,664
    1,042
    United States
    Hmm, a bit more rust than I'd want to see, and sounds like the battery was overcharged at least once. Anyone buying a used Prius should pay a Toyota technician to thoroughly inspect the vehicle first to see what's wrong with it.
  5. bisco
    50,801
    my 08 is completely clean, i think you are wise to ask the question and look at some more before deciding.
  6. Patrick Wong
    18,200
    6,490
    The rust doesn't look that bad to me.
    Regarding the "open" wires, if you think that is bad, wait until you see the 2010 Prius with the engine ECU located in the engine compartment and the many wire connections exposed in that fashion.
  7. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yes, I was shocked when I opened the hood on the 2010.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I noticed this same rusty bolt in your picture
    on my 2009 about half year after buying it new.
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Just some electrolytic action caused by different metals, However, the last picture shown bu the OP: that spring area is really corroded ( in 2 years?) I suspect some sort of direct salt water immersion. Probably little to NO maintenance has been done on the car. Incidently, " KUDOS " for checking out a car so thoroughly, before, ..........buying. Unless there is a tremendous discount, let some fish buy the car.:cheer2:
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Thats an easy one. Just spray a tiny bit of the stuff linked below on every bolt head, every door hinge, every connector, the aux battery connections especially at the ground. The rust will stop and it will waterproof the connector.
    Been doing this to my cars for 30 years. Years later Just wipe it off and brand new metal underneath.
    Its a great product because its more grease than spray and does not smell bad like say WD40.
    What your seeing is dry to the bone metal parts living in a very wet climate. Go look at your car at 3AM. Its soaking wet from the dew.
    Bad news is if your getting that corroded up top the underneath is really bad.It will attack your exhaust system really bad too.
    Not to much you can do about that.
    I hose off the suspension parts with this stuff too. Don't go crazy just enough to lubricate the surface. Especailly the trailing arms front and back with there rubber bushings. Those bushings dry out and corrode and you start getting really sloppy suspension and lots of noises.
    A girl at work asked me one day If I knew about car squeeks and rattles. I said kinda. She has a 2002 CJ5 Jeep WRangler. I looked under the car and it was clean as a whistle and everything was rusted. The leafs... everything. Under the hood everything was corroded. She said everytime it started to make noise she washed everything. Inside and out. I suggested my grease plan. She said no then everything will look greasy. I said thats a good thing. It a car. A machine.Machines like lubrication. Not rust.
    3 spray cans later no squeeks.
    Home Depot here not sure where in London
    PM me I'll ship you some
    http://www.tooltopia.com/blaster-16...tm_term=BLP16CSP&utm_campaign=pricegrabber_r1
  11. richard schumacher
    7,664
    1,042
    United States
    Amusing website, that. Yes, I definitely don't want any nasty carcinogens attacking my car. Car cancer (would that be a carcinoma?) is the worst :_>
  12. 2009Prius
    2,705
    511
    63
    The spray does not harm rubber parts?
  13. The Electric Me
    9,083
    5,800
    Reading the description it protects my car from "carcinogens"? So now my car can get cancer? Wonder if they offer any product that protects against high blood/oil pressure and clogged arteries or fuel lines.
  14. kwasmart
    kwasmart cool member
    chiacago
    my suspicion is that this one has been underwater- flooded in the past. My 04 prius looks better than this. do a carfax, or whatever you have about. best of luck.
    kwasmart
  15. boppo
    boppo Active Member
    799
    138
    Owego, NY
    That's why mine sits in the garage all winter.
  16. edthefox5
    10,096
    4,829
    Clearwater, Florida
    No. But not to be used cosmetically like on rubber body mouldings or door seals as its really grease. I use Protectant on the body stuff but underneath where you have a really hard rubber bushing like in our trailing arms and a metal bushing surface this stuff is perfect.
    I do spray Protectant on the CV joint boots inner and outer though.
    If they dry out and crack its a hassle. If you keep them conditioned they'll last a very long time or at least until the CV joints need to be replaced.
  17. edthefox5
    10,096
    4,829
    Clearwater, Florida
    No its just London. London is rainy, foggy and very dewey in the am. Not bad rust at all just never maintained. That "bonnet" latch mechanism has never seen lube in its life. One day the bonnet hatch release will not release. That sucks.
    The real horror is underneath.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The North American model doesn't come with a bonnet. This must be a U.K. option. ;)
    Tom
  19. 2009Prius
    2,705
    511
    63
    Any particular brand of rubber protection spray do you recommend? Thanks!
  20. edthefox5
    10,096
    4,829
    Clearwater, Florida
    I really like the "Black Magic" line of car products. There Protectant works really good for rubber,cv boots, door mouldings.
    And there tire product is very good also. Available at any auto store and Walmart.
    A dryed out ripped cv boot is such an expensive hassle when all you need to do is keep it pliable.
    This stuff:
    Black Magic Car Care Products - Black Magic Pro-Shine Protectant
