scan guage error codes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rmacguy1949, Oct 23, 2016.
  1. rmacguy1949
    rmacguy1949 Junior Member
    arizona
    can the scan guage II read toyota error codes? how?
  2. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Unless there is something very particular about Toyota diagnostic codes, I would expect that you just plug into the OBD II connector, press Menu, then Scan. You should see any stored codes. Then, if you want to, you can clear the codes.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    ScanGauge will only read standard engine and emission codes generated by the Check Engine Light. It can be programmed to read Prius specific HV Battery DTC's but it is pretty complicated.
