scan tool thingy, questions
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Dec 23, 2007.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    well, the elm232 and related are mostly about the interface hardware,
    and it's not clear the associated software knows about all the
    manufacturer-specific parameters and how to interpret them into
    accurate data about the prius. Attila's work is more about
    passive listening on the bus, which is completely different from
    issuing OBDII queries and getting answers back from the ECUs.
    You can use the elm232 hardware to do passive listening, but
    without setting the acceptance registers really carefully you're
    likely to get totally overwhelmed with data.
    _H*
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Not with those products.
    You will need a MSO (Mixed Signal Oscilloscope) with the appropriate CAN trigger module to capture the SOF. Remember that the scope will need sufficient memory to trigger on StandardID (11 bit) and ExtendedID (29 bit)
    It's very helpful if the scope allows you to trigger a specified ID to a data frame, and a specified ID to a remote frame. A lot of the cheaper scopes will experience common mode deviations and render your "data" garbage (Garbage In, Garbage Out).
    Memory depth and speed is very important to separate the CAN triggers/messaging from the "noise." Thus, I prefer a scope with at least 2 GSa/s, 300 MHz, and 2 Mpts memory
    The aftermarket scantools do not have access to the proprietary CAN messaging that Toyota uses. Legally, they only need access to the OBDII requirements. Although companies like GM will make the extended messaging available, I see no indication the Asian makers will do so
    We use Agilent 54600 and 6000 series scopes, with the optional CAN trigger module, as the industrial CAN is very similar to automotive CAN.
    I hope you are independently wealthy, such a system will set you back $35,000 and up
  5. statultra
    798
    31
    Edison,NJ
    2001 Prius
    ok i bought the CAN USb adapter, and im wondering what i can use to access HV ECU info and Hv battery?
    also i want this to work with the 01 prius
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    You will have to know the specific ID's of the modules you wish to interogate.
  7. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    The Gen1 Prius is not equipped with CAN.
    Ken@Japan
  8. statultra
    798
    31
    Edison,NJ
    2001 Prius
    i understand the 01 isnt equipped with CAN but i also have a ELM 327 adapter, would that be able to access the HV ECU on the classic prius?
    as far as i understand its ISO 14230 I would have to send a command to initiate communication?
  9. ken1784
    2,943
    1,381
    67
    Yokohama, JAPAN
    Only Graham Davies knows how to communicate with Gen1.
    ECROS Technology - Prius Mini-Scanner
    Ken@Japan
