Scangauge and Grill Blocking
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TEW, Nov 11, 2008.
  1. TEW
    TEW New Member
    Virginia
    When grill blocking, what scangauge values do you monitor? Engine Temp? Water Temp? MG Temp?
    As a corollary, what values do you monitor the most other than ignition timing and current?
    -tew
  2. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    I used to have both water and engine temp gauges displayed, but they rose and fell togather so I dropped monitoring engine temp.
    Someone correct me if I'm wrong, but MG temp isn't available.
    Other gauges are RPM and current in/out.
    The last gauge varies. At the moment it's set to percent full for the gas tank. I was watching the difference between the number of pips and the percent full.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Temps of both MGs are available in the CAN data stream and therefore theoretically available via an Xgauge. (I monitor them with CAN-View.) I don't recall right off if anyone has actually found it for an Xgauge.
  4. TEW
    TEW New Member
    Virginia
    Thanks for the help.
    For water temp, what value (or range) do you consider to be "prime" for the ICE and what value should you never exceed?
    I have read some posts from people on this site talking about MG temps, but they may have CANview. It is interesting thought that someone hasn't figured out the values for the xgauge. I will do some research on it and see what I can find.
  5. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    184 to 186 is prime
    194 to 196 is the normal high
    Those are my observations. I've never witnessed anything higher than 196°F on my ScanGauge, but I'm sure you'll hear someone chime off that an additional 10 degrees is just fine.
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The Prius coolant is 50% propylene glycol (with lots of other junk in it ;) ). At 10 PSI this boils above 120C. I have seen 95C on the highway with both grills blocked and an ambient of 30C (about 80F). I suspect it would be difficult to cause the coolant to boil unless you got ridiculous in the blocking. The engine is just not powerful enough.
    I monitor:
    Engine RPM---------------------------------Coolant temp
    Fuel use (l/hr)------------------------------12V system voltage
    I have a second Scangauge II and the plan was to monitor HV battery voltage and current. Haven't gotten around to connecting it and programming it. I may not bother. The information is superfluous, as the car seems to be smarter than I. ;)
  7. TEW
    TEW New Member
    Virginia
    Thanks, all. I appreciate the help.
    I'm going to go down now and start stuffing pipe insulation into the grill.
  8. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    I haven't seen MG temp either when I was creating the simplified ScanGuage manual with a few extra gauges listed for the Prius. (Link, in case you're interested: View attachment 10537 )
    Check this thread for more information, but again, no MG temperature (but MG2 torque is available). Dan. might have more information by now.
  9. TEW
    TEW New Member
    Virginia
    Has anybody talked to the guys over at Hybrid Interfaces? If CANView is pulling the MG temps off the CAN stream, then it would seem logical that you could parse the value with a scangauge.
    Thanks for the link to the modded scangauge manual.
