ScanGauge vs OBD II Scanners
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Fastronaut, Dec 16, 2011.
  1. Fastronaut
    Fastronaut Junior Member
    63
    I haven't owned a Prius before, so please excuse the novice question.
    Is it necessary to have a Scangauge for the Prius v or will any CAN OBD II Scanner work? What's the best to have for the Prius if you had to select one as of today?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    From what I have read and understand there are no OBD II scanners currently available that will read all of the Prius specific diagnostic trouble codes (DTC).
    The ScanGaugeII will read most, if not all, of the Prius specific DTC plus will allow you to change some of the Customizable Features that you would have to otherwise have the dealer do. There is also a spreadsheet of custom XGauges that you can configure to read a lot of the Prius hybrid system data such as HV battery voltage, temp, etc.
  3. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    You may want to check out this thread for the Torque Android App.
  4. Fastronaut
    63
    It looks like there is also an app for the iPhone as well. Thanks.
