Searching for Wiring diagram for 2012 Prius JBL radio/amp
Discussion in 'Gen 3 Prius Technical Discussion' started by JC91006, Dec 24, 2023.
  1. JC91006
    16,632
    8,492
    Would anyone here have a wiring diagram for 2012 Prius JBL system? My amp cut out and I'm trying to see if I can find the cause of the failure.
  2. ChapmanF
    16,948
    It's just the regular wiring diagram for the car:
    Toyota Service Information and Where To Find It | PriusChat
    It has the various JBL/non-JBL, nav/non-nav options all shown, in different sections or with different numbered asterisks by the wires.
    You're welcome to these quick notes I cribbed eight years ago, but they're definitely terse. Looks like I wrote them in a [number][circuit]=[color] format, which would mean connector L130 position 9 is the CANH circuit and green, position 10 is CANL and white, and so on. Notes like (nxt 3) or (prv 2) I added on shield drain connections to indicate which circuits run in that shield. Beyond that, I myself would have to look at these notes a lot longer to figure out what I meant by them eight years ago.
    Code:
    A L111 90980-12553 0.64 III f
      6PKB=R
      7CA+=W 8V+=R 16V-=B 15CGND(prv 3) (camera)
    B L127 90980-10997 2.3 II f
      3ACC1=GR 4+B1=SB 7GND1=BR 10ILL+=G
      1FR+=G 5FR-=B 2FL+=R 6FL-=W
    C L128 90980-10996 2.3 II f
      2RL+=Y 6RL-=BR 5ILL-=W-B
    D L130 90980-12555 0.64 III f
      1IG=B
      6SNS2=B 4MACC=R 5MIN+=B 19MIN-=W 18SGND(prv 3)
      7TX1+=G 8TX1-=R 20MUT2=B
      21SW1=R 22SW2=G 23SWG[+]=P (steering switches)
      25ADPG[auxi?]=W 26VAR+=B 27VA-[asgn?]=W 28VAL+=R 11AGND(prv 3)
      2REV=P 9CANH=G 10CANL=W 17SPD=V
      Oh, and by the way:
      12Vshld 13Vcomposite 14V- (directly short ADPG to AGND when video present)
      http://priuschat.com/posts/1791217
    E L131 90980-12916 hardtofind
      1{jack assy 1} 2{jack assy 2} 3{jack assy 3} 4{jack assy 4}
      USB +5         USB D-         USB D+         USB GND
      jack assembly: 86190-48030; superseded by: ? 86190-0E030 ? yes.
    JC91006 likes this.
