Sears Craftsman 12V portable compressor!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ichiro, May 26, 2008.
  1. Ichiro
    Ichiro Member
    335
    SF
    Just got this delivered a couple days ago, and I'm pretty satisfied with what it does for $19.99. The digital pressure gauge alone is nearly worth $20.
    My only gripe is that it's very slow (since it is powered by the car's 12V accessory battery), so it's best suited for a few psi increments. Which is all I usually need.
    A big thanks to whomever it was that posted this in another Priuschat thread! :whoo:
    Craftsman 12 volt Air Compressor/Inflator, Rechargeable/Cordless - Model 75116 at Sears.com
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    These are indeed, worthwhile. I've seen price drops on other brands to under $12.
  3. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    As one of the many who has recommended a Craftsman portable 12V air compressor, you are welcome.
    Question: Did you purchase the cordless one (75116) or the corded one with the digital readout (75114)?
    I have the latter and am very pleased with it. It is not underpowered, and I think it does the job well and quickly. Cordless would be nice, but I don't know that it would provide the consistent power (it also is much more expensive). I also like the digital readout and the ability to set the pressure and then have the compressor fill the tire to that PSI. I also like the ergonomic features of the unit. Everything fits on the compressor or wraps into it. It stores in very little space, and it is not expensive. Right now, Sears is selling it for only $19.99.
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I have both and was not impressed with the cordless one. The hose gets very hot where it exits the unit, and there are a number of reports of it breaking in the comments at the Sears site.
    The corded one, however, seems quite nice.
  5. drees
    drees Senior Member
    1,782
    247
    I got one and it blew the fuse on the unit and on my Prius the first time I tried to use it. Still haven't had the time to return/exchange it for a different one.
  6. Ichiro
    Ichiro Member
    335
    SF
    Hmm... I haven't tried it on the prius yet. It worked fine on our Volvo S40 however. I was more worried about depleting the 12V battery.
    I think I'm going to use one of these things to power it instead
  7. drees
    drees Senior Member
    1,782
    247
    Mine was definitely defective, as it shouldn't be blowing fuses. I just hope that the replacement is also not DOA. It would blow a fuse when trying to inflate anything. Turn it on without a load and it would run.
  8. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    My dear Father gave me one of those portable jump-start packs with compressor built in, that he'd had and was no longer working. The compressor was not pumping air.
    I took it apart and removed the head and piston from the cylinder. Turns out the compression ring around the piston had folded over (just plastic). So I folded it out and lubed everything, put it back together and all works quite well now. These things are worth $80.00 bucks and I've got a good one. It took 15 min. to fix
    It's just a single cylinder engine that is electric driven. Don 't run 'em too long or they overheat and fold the ring.
  9. geognerd
    geognerd Junior Member
    37
    Elgin, Illinois
    How has the corded model (75114) been holding up? I was leaning toward getting a model you plug into the wall instead, but it sounds like everyone is having good luck and getting adequate performance from this Craftsman 12V model. Also, does it go on sale for $19.99 often? At the moment, it is about $35.
  10. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I bought the cordless one in around 2000. That was 9 years ago. I don't use it very often and haven't been charging the battery unless needed. It still works well. I am especially amazed at the long life of the battery despite the lack of maintenance charging. Wish my car battery is like that.
  11. ski.dive
    ski.dive Active Member
    959
    242
    Hutchinson Island,FL. Mt. Snow,VT
    Just get a can of fix a flat
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Yes I have been using the corded one for about 2 years now. I keep it in the back of the Prius. It works good on the little Prius tire but will not pump up the tires on my Crown Vic or truck though so its a Prius only thing which is fine with me.
