Setting EV mode on/off using CAN-BUS shield.
Discussion in 'Prius PHEV Plug-In Modifications' started by zolk, Nov 27, 2012.
  1. zolk
    zolk Junior Member
    Can be the EV mode turned on/off sending a CAN command using Sparkfun's CAN-BUS shield?
    Does anybody knows the codes?
    ( I could not find them in Attila's spreadsheet).
  2. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Arduino shield,carduino, and sparkfun may work............some are using the arduino mega 2560......
    However there are the followin issues/obstacles, OBD/OBD2, canbus 2, PID, and library for the toyota....
  3. zolk
    zolk Junior Member
    I already have it setup in my car, and it works fine.
    I am able read and send commands to CAN.
    I was just wondering if I somebody knows the CAN commands to turn EV mode on/off.
    The alternative is wire the arduino to EV switch.
  4. NortTexSalv04Prius
    915
    115
    Most non USA Toyota Gen2 Pri came without EV switch. A physical mini switch (momentary type) can be wired/spliced into the Gen 2... To get EV up and running has several requirements... Normally at IGN the prius gen 2 ICE will power on to warm cats,recharge HV trac battery. Hybrid Interface has a software force EV with its product. (kinda want one). With Gen 3 you should already have factory oem ,,,,,,,
  5. NortTexSalv04Prius
    915
    115
    They are different flavors of CAN/OBD/OBD2
    The PID , CAN, and CAN2 libary all vary and not sure if just one software command may possible to get you there for EV
