SGII on Gen 3 Prius IGN reads what?
Discussion in 'Gen 3 Prius Technical Discussion' started by tedjohnson, Jan 5, 2011.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    When the ICE is off (RPM=0) I get a reading of 5 ??? What ignition property is this reading, degrees before TDC? it seems to run into the 30's under heavy load. Anyone figure this out yet? I know Wayne likes to set this at 14 for best mpg and then pulses from 18 to 5 from reading other posts. Maybe 5 is some default reading ???? Thanks. Ted
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    FWIW, on the 2nd gen, when the ICE shuts down, IGN is also 5.
  3. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    yes found an old post which I can not just paste here for some reason. 5 is ICE off, 10 is idle, 13-18 are good mileage settings, >18 is lots of fuel use. Wayne's post had him operating p&g 18 to 14 for good mpg. Unclear what the numbers mean. Maybe half degrees before TDC, no one seems to know ????
