Shark Fin Antenna on Plug-In Advanced
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jbrad4, Jan 10, 2012.
  1. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I would really like to replace my standard antenna on my Plug-In Prius Advanced with a shark fin antenna. The main thing I'm concerned about in doing this is the operation of SiriusXM radio and Safety Connect with the shark fin. Does anyone have any experience in using a shark fin with these services? Is there any degradation in the signal with a shark fin?
    I saw a thread on Sirius, but my main concern is using Safety Connect with a shark fin.
    Thanks in advance.
    KLD_Prius_PI_Synergy likes this.
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The Toyota Sienna uses a factory shark fin antenna for XM radio reception. I believe Infiniti also uses a shark fin antenna on their models for XM reception as well. I image it would be fine.
  3. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    The tunning of the receiver/transmitter might be matched to the antenna the car is designed to come with. I can't imagine that the sensitivity would be the same if you switched.
  4. Charlie_P
    Charlie_P Junior Member
    Rehoboth, MA
    I have installed the shark fin offered on this site and have noticed a major reduction in my XM reception. I thought that the stick was only for AM/FM
  5. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    AM/FM is in the passenger rear small window.
    I have the sharkfin from this site on my advanced PiP and I notice no difference in signal for XM.
  6. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I stuck a swim flipper there and I don't get reception, but my car seems to head towards the ocean nightly.
    surfinjoe and rogerv like this.
  7. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    DianneWhitmire likes this.
  8. PRPrius
    PRPrius Active Member
    327
    198
    I have a shark fin on my Advance and have not had any issues with XM. Howerver, I am expiriencing issues with the signal reception for the local FM station's HD channel. HD signals are not that strong to begin with and by removing the antenna, the car spends a lot more time on the FM than HD for my favorite local station. This being said, I am perfectly fine making that sacrifice for the looks of the shark fin.
  9. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    FM antenna is not on the roof. Shark fin cannot affect fm or am.
  10. PRPrius
    327
    198
    Actually, the Prius has 2 AM/FM antennas. One is the roof mounted antenna and the other one is an in-glass antenna. The roof mounted antenna is composed of two sections. The detachable section which sticks out like a dogs tail is the AM/FM antenna. The lower section which is part of the base, is the XM satellite radio reciever. For 2012 they added an in-glass antenna to the passenger side rear quater window. I am sure after listening to a lot of 2010-11 owners complaining about AM/FM reception. The Prius has always had the main AM/FM antenna on the roof of the car. However, if you look at the Gen I and II the base is very small due to the lack of the XM reciever. This actually was a cause of concern, when the Gen III was introduced. We didn't think the shark fin antenna would be able to fit over the larger Gen III base.
  11. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    The owners manual does not agree with you.
