Sharkfin?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sleeka, May 29, 2009.
  1. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    Has anyone tried to fit a Sharkfin antenna to a 2010 yet?
    It may be a tight fit with the Solar Panels.
  2. Danny
    Danny Admin/Founder
    7,093
    2,116
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I have a feeling that the folks at VisualGarage are going to have to redesign the Shark Fin. As soon as I have mine (hopefully next week), I'm going to try fitting a Shark Fin on my car.
    We'll have them up in the PC Shop soon enough!
  3. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Danny, Can you confirm that they will have satellite antennas in them as well? And if so, will they only receive XM, or will they also get the Sirius stream?
  4. sleeka
    sleeka Member
    249
    Hey Danny, have you had a chance to try a fin on your new Prius for fit yet?
    Would be good to know if the current type fits or not.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    This is the first car I've owned in a while that had an actual stick antenna (as opposed to one built into a window), and the FM reception is great. I live in a hilly area, and I can now get clear reception of many stations I couldn't in previous cars.
    Does the shark fin replacement antenna noticeably reduce reception?
  6. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    The Shark Fin antenna on my '07 reduced reception by about 15% if I were to guesstimate. I never missed the reception, but it was noticeable and most likely will be the same on the '10. But the thing looks great! I'll be interested if they come out with a Blizzard Pearl one, Danny!
    Lee:cool:
  7. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    The XM reception in the 2010 leaves much to be desired. It seems to drop more often than in my 2009. Hopefully the shark fin will improve the reception. But, I will not hold my breath.
  8. lov2krz
    lov2krz New Member
    San Jose, CA
    I have the 07 with the XM square antenna in the window. I need to know if I purchase the Sharkfin for it will I be able to run the XM antenna to the roof and will it fit under the Sharkfin?
    Thanks.:eek:
  9. Gadgetdad
    462
    Modesto, California
    There seemed to be enough room on the underside of the sharkfin for my '07 for the xm antenna. I'm sure Danny will give us the possibilities when he has a sharkfin available for the '10. Do a search on previous threads re: sharkfin to find out more.
    Lee
  10. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
    Is there a possibilty that water could get trapped underneath the fin and cause paint damage? Is there a water tight seal and/or built in weep holes?
  11. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    dbacksfan,
    The Sharkfin is attached to the roof with a one-piece 3M double-sided
    sticky tape perimeter gasket.
    There are no holes of any kind in the fin itself.
    If a fin is manufactured specificaly to fit the curve of the GenIII roof, it
    should be a drop-on fit without distortion or warping. If you properly
    clean the mounting area to get rid of all dirt and wax, and attach the
    gasket to the fin without wrinkles it is unlikely that it would leak.
    FWIW, water under the fin probably wouldn't pose a problem for the
    paint. However, it might lead to accelerated corrosion at the
    connection where the fin's antenna lead is bolted to the OEM antenna
    base. It's best to cover that connection with some conductive coating.
    There are pictures of the gasket, etc in a thread from about two years
    ago. Using the search function with "Sharkfin" as the search term
    should turn them up.
    EDIT: After pondering on this for a while, I've remembered that the pix
    included one of the electronic bits in the fin. The antenna itself is folded
    "fractal" style. So perhaps that would be a better search term.
    Hope this helps.
  12. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
    Thank you for your response. I'll take some time to do additional searches.
    BTW, I'm most concerned about tap water from washing my car. The water here is very hard. If left on the paint for a prolonged period of time, the deposits will definitely cause permanent etching in the paint finish.
  13. afastcar
    afastcar Junior Member
    AZ
    Hello Im new to the forum, I have searched and searched for info on the sharkfin antenna for the 2010 with solar and this is the only post I can find but it doesn't answer if it fits or not, does anyone know if it fits?
    I know it diminishes the reception I know its not factory, but I like the way It looks, thanks for any info.
  14. Danny
    Danny Admin/Founder
    7,093
    2,116
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Nope, the Shark Fin does not fit the 2010 Prius with the Solar Roof. It will fit the standard packages, but not the solar roof package.
  15. afastcar
    AZ
    Is it way off, is the mount different on the solar car, or is the fin to long and hit the solar panel? I really like the look of it and have a good body shop that can do about anything. thanks for your time.
  16. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Keep in mind - I believe everyone has reported worse reception. The AM/FM reception in the 2010 is poor as it stands - this will compond that...
    One person reported it got so bad, they had to remove the antenna, and put the old one back on.
