SHIFTER in the Gen 3
Discussion in 'Gen 3 Prius Main Forum' started by 007, Nov 2, 2010.
  1. 007
    007 New Member
    157
    Antigonish, Nova Scotia
    Here's a question, hopefully it doesn't sound too dumb, apologies if so....
    When driving, it would be dangerous to accidently hit the shifter in the centre con while in "D".....has it ever happened that someone hit this while driving? Can you swipe it with your hand or arm and cause damage to the car? It seems so small, it looks like it might be easy to hit by accident.
    Other cars, the shifter locks in the D or R position until you press the brake.
    just wondering?
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    The worst that could happen would be going into neutral.
  3. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    Don't worry most all the Gen I, II, & III it takes a few seconds of holding the shifter in it new position to make it shift out of D. So just accidently hitting the shifter should cause no problems.
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    As stated above, if you hit it to "R" it would go to "N" and beep at you. If you hit it to "B" it would go into that "gear" or "mode", and you can easily shift back to "D" (the cruise will cancel when it goes to "B"). If you press the "P" button, it will go to "N" and beep at you. If you hit it to "N" it will go into "N". You can then shift back to "D".
    There is, also as stated above, a delay, of about 1/2 to 1 second before it will act on your "request". So a quick bump won't do anything.
    None of the above will do any harm. The engine won't overrev. and no gears will end up on the road. ;)
    It's electronic, not mechanical. It's smarter than most drivers.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Though will it not try and engage R or P if you select them at about 5 mph?
    If it does (and I haven't tried it) it could cause significant damage to the transmission, but then again, this would occur with most automatics on the market.
  6. guinness_fr
    guinness_fr Junior Member
    68
    france
    Around 5mph, shifting to R won't do any harm (I do it quite often, I kinda like the way it brakes for me). Now pressing P at 5mph might get ugly... :eek:
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The Gen 2 and Gen 3 have essentially the same system, and I have tried all of the combinations in a Gen 2. As pointed out above, all that happens is shifting to N. The Prius won't let you hurt it.
    At very low speeds you can drop it into park. Supposedly it won't hurt anything, but you will stop right now. I don't recommend it.
    Shifting to R at low speed is fine. I do it all the time in the winter, when I need to rock it out of snow.
    Tom
  8. 007
    007 New Member
    157
    Ok, I feel better now, that did have me concerned since its such a little joystick, I knew you guys would have the answers.
    BTW....my friend at his Toyota dealership emailed me today, and said we should get together and put my order in for the 2011 Prius II BP, so I'll have it in plenty of time for May 2011. He said it should take about 3 months for a special order, so we're ordering it a bit early in case of any unforseen problems.
    175 days.....and counting.
  9. David Beale
    5,963
    1,985
    Edmonton Alberta
    Oh, you're ordering a 2011. They have recalls on those! When you put it in "D" and release the brake they move! VERY DANGEROUS!!! ;)
  10. 007
    007 New Member
    157
    ha...you had me for about 4 secs, on the second read.
    duhhhh, sure hope it goes in D.:D
  11. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I could not find on the Owner's Manual beyond which speed will P not engage and go instead to N - any ideas? There must be some max speed that the mechanics can sustain to engage P beyond which, electronically, the Prius will simply shift to N to avoid any damage.
    PS: in 14 months of driving the Prius I never managed to indadvertedly touch the shift lever, and, as mentioned, any change takes "some" time - it is not instantaneous.
  12. qbee42
    18,058
    3,076
    Northern Michigan
    It's around two to four mph. I don't know the exact speed. It's fast enough that you stop very abruptly, but not fast enough to hurt the parking pawl.
    Tom
  13. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    The Prius is very protective of itself.
  14. Tideland Prius
    16,403
    I recall seeing the 8 floating around.. can't remember if it's 8mph or 8km/h.. I do think it is higher than 2-4mph.
