Shifter not working after Re and Re
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frank Quigg, Mar 17, 2023.
  1. Frank Quigg
    Frank Quigg Junior Member
    V4R0B6
    Removed the shifter from 2006 Prius. It was working perfectly. Reinstalled it and now I get the P0705 code and it will not shift into gear. Neutral only.
  2. dolj
    dolj Senior Member
    8,446
    4,290
    Wellington, New Zealand
    Recheck your work. The most probable cause is something was not reconnected or a connector did not "click" when connected
    51,932
    unfortunately, a lot of old toyota connectors cannot take re re. you may have to re (place)
  4. Frank Quigg
    V4R0B6
    Thank you for taking the time to help. I took it apart and checked the plugs. You were correct, even though the plug-in clicked what had happened was a pin got bent to one side and was not in the female plug. it was bent and had a kink in the middle so it took some careful unbending to get it lined up. Works perfectly now. Thanks again!!!!!
    Thanks for trying to help. Turned out a pin got bent and I was lucky this time.
    #4 Frank Quigg, Mar 20, 2023
