hi i just got oil change, shop put in 5 quarts instead 4.5 quarts, is it ok or should I tell them to take out 1/2 quart? will mpg going to lose some? thanks all V/r Khoi Nguyen
Use the dipstick, check the level. If it is above the maximum fill line (second dot), you need to drain some. Simple as that.
I would drain it out until its either on the 2nd dot or between the min and max dot, it can cause problems for your vehicle if its overfilled.
The top dot is the max fill line. If it is over max fill, it is overfilled. Easy to just suck some up the dipstick with $1 worth of aquarium tubing.
