Should I Replace My 6-Year Old 12V Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by berryman, Nov 9, 2010.
  1. berryman
    berryman Junior Member
    55
    Southern California
    I have a 2004 Prius with 140K miles on it. The 12V battery has never been replaced and recent health checks indicate that it's operating within specs. Should I replace it now before I start having problems OR continue to run with it until problems show up?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Yes replace it asap. Only because unlike any other car out there on a Prius its somewhat dangerous to expose the car to a jumpstart.
    So you want to avoid that possiblity at all costs.
    Many many posts of major electrical damage using a jumpstart. Most likely by people inadvertently reversing the polarity of the jump leads which for some unknown reason happens alot to a Prius.
    Here's the standard very simple & easy boot battery test to convince yourself:
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I agree with Ed, not just because of the consequences of reverse-polarity jumping (and the age of your battery), but also because of the sudden, peculiar, and potentially serious symptoms of a dying Prius 12V battery. (Do a good search here if you need more.) I replaced mine as a preventive maintenance measure after 4 years.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Also make sure the replacement battery is fully and properly charged BEFORE you install it. The way the Prius handles 12 v battery charging, if you install a "new" battery only partially charged, you will have a chronically undercharged battery and shorter battery life
    With my former 2004 Prius, and now my '07 FJ, I leave the battery plugged into a VDC Electronics Battery Minder whenever I'm not driving the vehicle
    With my FJ, I was somewhat surprised after going over all the maintenance records, how much I drove it the past year: 6,458 km over 12 months
    Due to business travel, the FJ can sit in my attached garage for upwards of 2 weeks at a time. The Battery Minder keeps the battery at the proper charge, and desulphates the battery too
  5. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Agreed, replace it. At the very least, when it fails, it'll be a hassle (and of course Murphy's Law indicates that it will happen in the rain, at 2:00 in the morning, in a questionable neighborhood, with your teenage daughter driving the car).
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
