Should I stay or should I go? (Repairs vs selling)
Discussion in 'Generation 1 Prius Discussion' started by sheepe, Jun 7, 2014.
  1. Sell it
    16.7%
  2. Fix it yourself! Builds character!
    83.3%
  3. Let the mechanic take care of it!
    0 vote(s)
    0.0%
  1. sheepe
    sheepe Junior Member
    Ohio?
    2001 Prius
    Howdy y'all,
    I've recently brought my 2001 Prius into the shop to get my flaky A/C system and an engine light checked out. As a courtesy, they did a basic check through of everything else. Unfortunately, they found that my baby is in significantly less than optimal condition.
    So now I'm debating the value of selling my car vs repairing it.
    Mileage: Bought at 157,628; currently: 213,772.
    Time owned: 3 years, 5 months
    The issues:
    P3191 Code
    Solution: This was fixed by cleaning the air flow sensor​
    Air Conditioning/Heater clutch air gap spec is .15mm actual .783mm. air gap is way too large and causing occasionally the compressor to not engage
    Solution: Replace Compressor
    Cost: Mech: $202.89 labor, $842.04 parts || Self: Low confidence with A/C, $420 parts​
    Suggestion: Replace condenser at the same time to save on labor
    Cost: Mech: $375.71 labor, $385.56 parts || Self: Low confidence with A/C, parts not found
    Also $109.79 to evacuate and recharge A/C system || Self: $40​
    Drive Belts Cracking (also referred to as serpentine belt?)
    Solution: Replace
    Cost: Mech: $53.89 labor, $57.42 parts || Self: $19 Dayco belt
    Front Strut/Shock Left Side
    Damaged
    Leaking Badly
    Front jounce stop is damaged and wedged up in the strut. And the left side strut seal is blown out
    Image(s):
    http://tinyurl.com/k6a5qon
    http://tinyurl.com/q8uvvwk
    Cost: Mech: $388.59 labor, $605.94 KYB parts || Self: $245.96 KYB parts​
    Rear Strut/Shock OEM
    Heavy Leak
    Soft
    Worn
    Image(s):
    http://tinyurl.com/lajvr9t
    http://tinyurl.com/l3ok734
    Solution: Replace all four struts/shocks and align vehicle
    Cost: Mech: $388.59 labor, $595.94 KYB parts || Self: $245.96 KYB parts
    Cost: Alignment: Mech: $89.95 || Self: $65 ​
    Total costs:
    Mechanic: $1,876.37 labor and $2,486.90 parts. With sales tax and job supply fee: $4,425.16
    Self: Hours of quality time with my car, $105 +$5/hr hobby shop fees, $911.91 parts.
    And this is all on top of having spent: $413.56 to replace a wheel bearing and the battery.
    The final question is: Will replacing all these things, whether I do it myself or have a mechanic fix it for me, allow my car to survive for another 3 years (when the HV Battery is expected to go)? And will it do so without other major repairs? Or do I sell it now and move on?
    P.S: The mechanic is required to get parts that are warrantied out to 2 years/24k miles. This is part of why their parts prices are higher. All my parts were sourced through AutoZone
    51,169
    none of these are absolutely necessary to keep driving the car, and you'll probably continue to make repairs after all this is fixed. sounds like they are more than the value of the car. i would say go.;)
  3. JC91006
    16,674
    8,519
    Sounds like a lot of money for a car with 215k miles. I would get a quote at the dealer or another mechanic. I don't know of any mechanic that marks up parts more than 100% of the actual cost
    SM-N900P ?
  4. bwilson4web
    16,022
    If you have backup transportation and a place to work on it, order the problems, order the parts, and fix it yourself. If this is your only transportation, you're in a tough spot.
    Read the sticky about who should own this model car and rate yourself. Personally, I don't see anything on the list that will keep you stranded by the side of the road. Although the belt is important, it makes sense to buy the spare and carry it in the car with the tools to replace it. Then combine belt replacement with the A/C shim fixed in a parking place or 'rent a bay.'
    The suspension parts are another thing because I suspect it requires heavy duty tools and a lift. I've not done it but IMHO, the ride might be a little snaky but tolerable. But I used to drive a Model A Ford and 'farm' equipment. I'm not a good judge.
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The air gap can easily be adjusted by removing some shims between the pulley can the clutch.
  6. ChapmanF
    17,389
    As others have pointed out, there's an easy fix that has nothing to do with replacing the compressor or opening the sealed system in any way. As the clutch wears, the gap is adjusted by adjusting the shim combination between the clutch shaft and pressure plate. Where did you get the spec figures you quoted? The actual ideal gap given in the manual is 0.5 mm. They allow a deviation of ± 0.15mm so maybe that's where the quoted number came from. Of course that really means 0.35 to 0.65 mm should be ok, and your 0.783 is somewhat too large. I'm not sure I'd say "way too large" as mine didn't even cause any engagement trouble until it hit 1.34! But if yours is causing engagement trouble now, sure, go ahead and adjust it. It'll take about 10 minutes and if you buy a whole new shim set at the dealer it will lighten your wallet by a dollar and twenty-one cents. You can do it with all four wheels on the ground, just steer to the right and drop the plastic engine under-cover on the right side.
    Please don't adjust it just by blindly taking out shims. Instead, measure the total thickness of whatever shim(s) you take out, add half a millimeter, subtract the 0.783 travel you measured, and what you get is the thickness you want to aim for with your new shims. The dealer kit contains a 0.1 mm, a 0.3 mm, and a 0.5 mm so you just choose whatever combination will make the thickness you need (within 0.15 mm either side). In my case there were two combinations that would be within ± 0.15 and I ended up using the fatter one, as the skinnier one did leave my clutch dragging slightly.
    It sounds to me like what you've really got is an A/C clutch shim adjustment and a belt replacement, which should both be easy and cheap and what I'd consider normal maintenance (they schedule the belt every 4 years), plus a couple of shocks (or all 4 if you want to work in sets). The question seems to boil down to whether a Prius at 214k is worth putting shocks on.
    If it were me and I could do it for ~ $300, I think I would. Just the hassle of shopping for a replacement vehicle would probably strike me as exceeding that. Pace Bob, I don't think you need especially heavy tools or a lift to get at the struts. Good jackstands and a breaker bar ought to do it. If you don't have a spring compressor (or you have a cheap one and aren't sure you trust it), you can take the new and old struts into a local shop just to have the springs transferred. As Bob said, it does matter whether you have a way to get around while working on it....
    -Chap
  7. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    X2
    This seems to me like a no brainer.
    AC - fix with $2 shim kit
    Drive Belt - Cost $15 and easy to install
    Struts - Front struts $60 each plus $50 at a shop to swap over springs
    Shocks - Rears $70 each
    Hobby space rental - local rate
  8. El Dobro
    El Dobro A Member
    7,075
    3,258
    Give it a go, in order of priority. (y)
  9. bwilson4web
    16,022
    Of course polling folks who already own and repair their own Prius might give a different result than if you asked the same question in "DealersChat.<model>.com". <grins>
    usnavystgc likes this.
  10. sheepe
    Ohio?
    2001 Prius
    Thank y'all for your responses. I did not know about the shim kit. That and the belt will be my first things to check. And Bob, of course I'd come here first, why spend thousands when you can spend a few hundred and get a few more years out of a good car. :)
    bwilson4web likes this.
  11. sheepe
    Ohio?
    2001 Prius
  12. ChapmanF
    17,389
    Yeah, "gasket kit"'s a funny name, but you can check the number in the photo here.
    For some reason, the new PriusChat forum software doesn't always take you straight to the right post following a post link, so you might end up looking at some other spot higher up the page. But if you just wait for the page to finish loading, put the cursor in the URL bar and hit Enter, you should jump to the right spot.
    -Chap
