SKS - Autolocking
Discussion in 'Gen 2 Prius Technical Discussion' started by Sunfire4jc, Aug 24, 2006.
  1. Sunfire4jc
    Sunfire4jc New Member
    32
    Hello there,
    I can't find this anywhere on the manual, but i remember my dealer saying with the SKS, if you walk more than 30 feet away from the car, it automatically locks. I keep forgetting to ask my dealer, i figure i would post it here. Is this true? if so, how do you set it?
  2. nmrickie
    nmrickie Member
    200
    New Mexico
    nope, he was wrong.
  3. gilfr
    gilfr New Member
    <div class='quotetop'>QUOTE(nmrickie @ Aug 24 2006, 09:08 PM) [snapback]309140[/snapback]</div>
    Hello,
    i'm french and want to buy a prius but i don't understand why as asked there is no way to set an Autolock feature in the Keyless system.
    For me the most imprtant thing on a keyless system is to lock the door when you leave the car. French Car manufacturer RENAULT include this on all keyless system, and that's very good.
    Sometimes with the Fob command, i forget to close the door... so an autolock fonction will be really a good idea.
  4. lkmcookie
    lkmcookie New Member
    My dealer said the same thing - the car would auto lock itself if I didn't press the handle/hatch and walked away. But its not happening.
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Dealers are perhaps the most uninformed people about cars, as sad as it sounds. The car won't lock itself, you have to do something (with the SKS, push the black button on the handle, without either use the metal key, or press the button on the FOB). Did your dealer also misinform you that the "B" on the shifter was for battery mode?
    Seriously, Toyota really needs to make an effort to correct some of these dealer misconceptions.
  6. aaf709
    3,862
    2022 Prius Prime
    It's sorta close, but if you use the fob to unlock and don't touch the car for 30 seconds, it re-locks. My wife's been caught with that several times. :)
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Pushing one of the little black buttons just becomes second nature in a short time. I don't think I could forget it now. When I drive my old pickup I find my self looking for the little button when I park it.
  8. Tideland Prius
    16,402
    <div class='quotetop'>QUOTE(Gilles @ Nov 6 2006, 10:41 AM) [snapback]344576[/snapback]</div>
    Renault is usually ahead in this field. They were the first with central locking and the first with this card-type keyless entry system.
  9. germain
    germain New Member
    I have another question on the SKS. I understand there are three options for keyless entry, but none of them seem very secure. What I mean is that ideally I would like to see an option where only the drive door is unlocked by using the drive door door handle. The reason I am concerned is that if my wife walks up to the car, someone could grab the passenger side door handle and get in the car. There does not seem to be a way to avoid this with the current three options. My only other option at this point is to disable the SKS, which means we would have to insert the fob into the dash. Not a huge deal, but I can't understand why a more secure option with the SKS is not available.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(ChicagoPrius07 @ Feb 20 2007, 11:04 PM) [snapback]393705[/snapback]</div>
    That is the standard mode: when you unlock by grabbing the driver's door handle, only the driver's door unlocks. If you use the hatch or passenger's door, then all of the doors unlock.
    Tom
