SKS fob battery dead, now what?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fibb222, Nov 21, 2008.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
    I search for 15 minutes and couldn't find anything about what to do if your fob dies.
    Do I have to go to a dealer to get the fob battery replaced and the thing reprogrammed?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
  3. patsparks
    10,664
    567
    Adelaide South Australia
    In the mean time use the key to open the door and insert the fob to start the car.
  4. Fibb222
    Fibb222 New Member
    1,499
    99
    Yes, that's what I did. A handy procedure.
  5. patsparks
    10,664
    567
    Funny things keys once you have not had to touch one for a while.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Which brings up a very important maintenance point: lubricate the lock cylinder on the driver door.
    In the average Prius, the metal emergency key never gets used. At least around here, you drive the car in conditions ranging from -40 C in winter, to +38 C in summer. Salt is used in winter to deice the roads
    Around a year ago, I noticed my Fob was getting weak. Drove to the mall, got a replacement battery, and everything was fine again. However, back at my house, I decided to try the emergency key
    My lock cylinder was so stiff/corroded it barely turned. As I was parked in my comfortable heated garage, no problem. Rummaged around for appropriate penetrating lubricant (Please, no snickers, I'm being serious here), and gently worked the cylinder until it was free again
    I'm now in the habit of lubricating the lock cylinder every 3-4 months, and using the emergency key to ensure it works smoothly.
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    Hobbit has a neat writeup on servicing the mechanical lock on the drivers door:
    Prius door lock
