smart key issues
Discussion in 'Gen 2 Prius Technical Discussion' started by ampollick, Feb 19, 2009.
  1. ampollick
    ampollick New Member
    Denver
    I just bought a used 2007 Prius. The smart key does not function like it should. It will start the car, and I can open the doors with the conventional cut key. However, it won't perform any of the "smart" functions, like keeping the key in my pocket and starting the car or opening doors. I've already tried a new smart key battery and the button under the steering column. And...I only got one key with the sale.
    Any ideas?
    My problem seems very similar to "Re: New smart key problem", except I don't believe any aftermarket items have been added to it, thus wiring should be okay. I'd post the link, but since I'm a newbie, I'm rejected from doing so.
  2. JohnnyPrius07
    JohnnyPrius07 New Member
    If it's under 36K mile I think it's still under warranty, you can at least bring it to the dealer for help.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Have you checked the SKS switch under the steering wheel? It is not uncommon for it to be accidentally pushed, which disables the SKS.
    Tom
  4. Patrick Wong
    18,200
    6,490
    If you bought your car from a dealer, perhaps you can go back & complain. If you bought from a private party, perhaps the prior owner had lost the two original fobs, then bought an eBay used fob, only to find that the car could not be programmed to accept it.
    If you want the Smart functions to work you'll probably have to visit your local Toyota dealer and pay ~$300 for each new fob and the associated vehicle programming required.
  5. sario77
    sario77 Junior Member
    Make sure you do not leave anything plugged into the center console power outlet, like a cell phone charger. The I-GO brand gave me Smartkey problems. The OEM one for my phone works fine.
  6. ampollick
    Denver
    Thanks for all of the suggestions so far. Unfortunately, it's not under warranty, I've tried the button under the steering wheel, and nothing else is plugged in. It'll really burst my bubble if I need to shell out another $300 for a key...
  7. captross
    captross Junior Member
    North East upstate NY
    Just to let you know, a factory fresh new key cost me $193.15 at the Toyota dealer in Burlington, VT plus $37.50 to program the new key. A previously used SKS fob can only be programed to work when inserted in the slot. None of it's push button or wireless features can be made to work. I have been there and tried that.
  8. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    i paid $180 for new Key and $90 programming in Calif a year ago.
    however, regarding your problem...sound to me like it's an Ebay (or used) Smart key that you have as it'll only work when inserted to start vehicle.
    so, if you want the SKS benefits, you'll need to pony-up abt $300 at the dealer. :(
  9. Stefx
    Stefx Member
    336
    2007 Prius not under warranty? That's a lot of driving!
  10. qbee42
    18,058
    3,076
    Northern Michigan
    What color is your key fob? You may have been sold a normal key fob, not a smart key. The normal key will start the car, but not do any of the smart functions.
    Tom
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    On the fob, is the Toyota emblem black or silver?
  12. ampollick
    Denver
    It's got the silver emblem. There's ONLY 53k miles on it--next to nothing for a Toyota!
  13. Patrick Wong
    18,200
    6,490
    Sounds like you have the correct fob type. You'll have to rely upon your Toyota dealer if you want to enable Smart functionality.
    It's possible that the car might be programmed to recognize the existing fob; more likely you'll need to purchase a new fob. You may want to consider doing whatever is required so that you end up with two working Smart fobs. In the event that one is lost it will be easier to obtain a replacement if you already have a functioning Smart fob. Good luck.
  14. qbee42
    18,058
    3,076
    Northern Michigan
    I believe the car can be programmed only to recognize a *new* smart key. This is done for security.
    Tom
  15. ampollick
    Denver
    10-4, I figured I would be going to a dealer... Thanks for all the help.
