Smart Key Problems.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by adric22, Nov 14, 2010.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    Okay, I've read previous posts on smart key problems, but my issue is slightly different than all of those.
    The problem started 2-3 weeks ago on my 2008 Prius. Both FOBs are affected. It will intermittently work, then not work. Some days I can walk up to the car and it works perfectly. And if it is working, I can do it 100 times in a row and it will still work. The next day, it may not work at all. And when it doesn't work, pressing the unlock button on the remote seems to not work either. I'll either have to hold the remove very close to the door while pressing the unlock button several times, and it will finally open, and on rare occasion I've had to use the little metal key. Once inside, I have to insert the FOB into the car to start it.
    So I replaced the batteries in both FOBs, no luck. Same issue.
    Okay, here is the part that may be different. I installed an Enginer PHEV kit in the vehicle around the same time all of this started. In fact, I had to remove the smart-key sensor in the cargo area temporarily while installing the PHEV. However, I've installed these kits before without problems, and I've even been in Enginer's own website and talked with people there who have these kits installed and nobody has had this problem. So it is safe to say that Enginer PHEV kits do not specifically affect smart-key performance, but I am not ruling it out, either.
    The thing that seems to make my story different from everyone elses is that both the smartkey AND the keyless entry seem affected.
    50,803
    i think it's related to the engineer installation.
    #2 bisco, Nov 14, 2010
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The type of intermittent operation that you describe can be caused by RF interference. However, the correlation with the Engineer installation is highly suspicious. I would start there.
    Tom
  4. SureValla
    SureValla Member
    590
    Shelton, CT
    I have a problem with my driver side door. It used to intermittently unlock via the sensor. Now it doesnt ever. Its not the batterys or the fob b/c it works on the passenger side door no problem.
    I used to always use my metal key until the mechanism for the release broke. I replaced it easy but now i just go unlock it through the passenger side.
    Its probably the door lock actuator but I'm too cheap to fix it in my case.
  5. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    As Qbee42 pointed out, Sounds like RF interference. The fob transmits at 312.15mhz, so if there is any RF in the area at that frequency, it will easily overpower the tiny signal from the fob. When you find it's not working, drive the car a few miles elsewhere and see if that changes it.
    I doubt the Enginer DC-DC converter is operating at this frequency, though it's possibly spurious harmonics could be emitted that can swamp the receiver depending on how good the RF front end has been designed.
  6. richard schumacher
    7,664
    1,042
    United States
  7. adric22
    642
    145
    Fort Worth, TX
    True, I haven't tested the 12V battery. By the way, it may be worth mentioning that the enginer kit will, by its very nature, be turned off when I am walking up to the car. So it is hard to suggest that it would be producing RF interference when it is just sitting dormant.
  8. qbee42
    18,058
    3,076
    Northern Michigan
    I wasn't suggesting RF from the engineer kit. I was suggesting that the installation of the kit has left the SKS in a precarious state. If you do have RF trouble, it will most likely be external.
    Tom
  9. Stocktonmanners
    Stocktonmanners aaaaaaa
    17
    hjkhljh
    Did you ever find a solution to this?
    I'm having the same issue.
    Thanks,
    Stockton
  10. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Adric,
    Be sure the Enginer box is well grounded to chassis ground. Wellnuts will cause this problem. Also the USB cable is an antenna. Be sure the display head is also at Chassis ground.
    Finally I fully agree with the 12v battery issue. Be sure to check that.
    Thanks
    Dan
  11. Orlousy
    Orlousy New Member
    Philadelphia, PA
    I have recently had this problem as well, only on the driver side. I noticed that if I press the little black lock button on the door, the lights will flash several times, the car will lock and then the if I put my hand around the handle it will unlock. I have also noticed that if I unlock the doors with the remote, all doors unlock but the driver side...there are variety of odd occurrences but all leading the driver door not unlocking. Does anyone have any insight or direction?
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I can't speak the issue that I didn't quote but the above sounds like it's behaving correctly.
    Assuming you have the SKS on you, pressing the black button == lock. Touching the back of the either of the two front door handles == unlock.
    As for what you point out as problems, you could try testing your 12 volt via http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html after the car has sat overnight. Tell us the values at each step.
  13. qbee42
    18,058
    3,076
    Northern Michigan
    This is normal operation, except that the lights flash once when locking.
    This doesn't make much sense. If the driver's door is unlocking with the SKS, then we know that the actuator is working. Unlocking with the fob should work the same way.
    Weird problems like this are usually the result of a bad 12V battery. How is yours?
    Tom
  14. scotrinaf
    scotrinaf Junior Member
    37
    Blountville, TN
    I have a similar problem to the OP's, I've noticed that if I push the "Valet button" under the steering wheel twice, it seem to fix the issue for a little while...
  15. bisco
    50,803
    do you also have an enginer kit installed?
  16. scotrinaf
    37
    Blountville, TN
    Negative, my car is 100% stock with the exception of interior LED lighting... (Just replaced bulbs with LED's)
  17. bisco
    50,803
    i suppose i would test my 12 volt and fob batteries. does it do the same with either fob?
  18. Bskija
    Bskija Junior Member
    I didn't check the other fob or another name would be key less entree' If it works on mine it should work on all Prius with the same year and gen. Of course, my device would only work on my car, your car would only work on your car.
    #18 Bskija, Feb 8, 2015
  19. bisco
    50,803
    not sure what you mean, they are only programmed to one ecu.
  20. Bskija
    I understand that both of the key less devices do the same things, but on my car only. What things the one does the other does the same. The panic button is a joke. For the car to start honking and lights flashing you must see someone tampering with your car. To do the test of your panic button you must first get far enough away from the car.to make sure the panic button is working by pushing it. Then you must get further away from the car so when you push the panic button it does not work because the signal is too weak to activate the horn and lights. Now that the device is too far away you should go another 15 yards to make sure the panic button still doesn't work. There is nothing wrong with the device or the panic button it just is not working because it is too far away from the car. Now press the panic button and at the same time point it at your head instead of pointing at your car. For some reason pointing at our head activates the horn and lights because the signal is now strong enough to do so. Pressing the red panic button again will shut off the horn and lights. The idea for the lights and horn to activate is to scare the car thief away from your car. In order to prevent the car thief from doing his thing you must see him do his thing. If I saw a thief I would call 911 rather than push the panic button or maybe do both.
    Bisco I am sure my devices do the same thing, but on my car only.
    Scotrinaf, I didn't compose the above. Somebody else did.
