Smart Keyless not working on passenger door
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dpoole34, Dec 5, 2009.
  1. dpoole34
    dpoole34 Junior Member
    Massachusetts
    I have a pkg 2 2008 Prius and the smart keyless entry is not working on the passenger door. I can lock the car from the passenger door no problem, but it will not unlock it. Drivers door and trunk are working fine. I have replaced batteries in both fobs. Any suggestions, or do I need to take a ride to the dealer?
  2. Patrick Wong
    18,200
    6,490
    Sounds like the touch sensor in the passenger door handle is not working, so a dealer visit would be appropriate.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I agree. The sensor should be covered under warranty. Take it to a dealer.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    It could also be a problem with the transponder coil on the passenger side, but that would also require a visit to the dealer.
    Tom
  5. firepa63
    1,761
    208
    Wouldn't a faulty transponder prevent locking the door from the passenger side?
  6. qbee42
    18,058
    3,076
    Northern Michigan
    With the SKS, yes. It should still lock with the fob. So yes, you are correct, the transponder can't be the problem.
    Tom
  7. dpoole34
    Massachusetts
    Thanks guys...off to the dealer I go
