Snow damage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ecooper45, Feb 7, 2011.
  1. ecooper45
    ecooper45 Junior Member
    Michigan
    I live in Michigan and we recently had a 8 inch snowfall. While parking my 2010 Prius it bottomed on the snow pile which took two pieces of black plastic off of the underneath front area of my car. Have others had this issue? Is there a website that has photos of the 2010 undercarriage? I assume the plastic is for aerodynamics, is there any website that has such parts, the OEM sites - I see on the web do not contain images of these plastic parts. Lastly, is there risk to not promply replacing the parts? I have an oil change coming in 2,000 miles and might just wait? Thanks for any and all help
    ecooper45
  2. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Speaking of oil changes, there is a door/cover for getting to the filter and drain plug. Some have broken it off while doing oil changes. That may have been one of the pieces you lost.
  3. ecooper45
    Michigan
    Thanks, I see that in another posting. Am looking for pictures of undercariage and the parts numbers to determine what parts may be needed. BTW nice bike - I ride a silver 2002 CBRXX (blackbird) when the weather is better. Tough to ride in the snow.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is not just for aerodynamics, it is mostly just to prevent loose crap from pinging the underside of the car. Small rocks, trees, and furry woodland creatures mostly.
    Do they make motorcycle chains? :p
  5. Tideland Prius
    16,559
  6. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    Yea, I did it too. Just the front most cover half hanging off. I didnt even try to do it myself with nowhere indoors to do it. Cost me $39 and 30 min at the dealer.
    It was my fault. I got tired of shoveling and used the car as a plow.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Welcome to PriusChat. Looks like you're getting plenty of help on your undercarriage issue. BTW, if you've identified the plastic pieces, what were they; i.e. oil cover door, under air dam, etc.?
  8. ecooper45
    Michigan
    Two pieces. One looks like the oil cover door. The other is a "felt-like" piece that appears to have separated from the oil cover door. probbably to deaden sound - I'd guess. I've now seen parts for the entire under-vehicle pastic listed around $200 and other recommendations by fabricating a hinge to reconnect the door to the other parts. Wish I could get under her and do it myself, but similar to others - no place to get to it in the winter - I don't have a heat garage! Have to deceide between dealer, body shop or regular mechanic.
  9. twittel
    1,605
    148
    Mt. Pleasant, SC
    I read some PC discussion about not needing to replace the oil cover door. I can't remember the thread, but I'm researching. Even if the consensus is that the door isn't critical, I'd still want to replace it.
  10. twittel
    1,605
    148
    Mt. Pleasant, SC
