snow tire advice
Discussion in 'Gen 3 Prius Accessories and Modifications' started by tedjohnson, Jun 12, 2010.
  1. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Hi all, it looks like I will need snow tires for the New England winter - Plan Ahead- Boiled it down to Blizzaks - studless, or General Altimax , studded. They both seem good from Tire Rack's perspective. Any experience in the group on either? I would suspect the Blizzaks would give better gas mileage, but the Altimax might give better traction? Thanks. Ted
  2. cnschult
    cnschult Active Member
    772
    97
    Michigan
    i use blizzaks (bridgestone) on my sisters corolla
    I use ice guards (yokohama) on my prius
    my dad uses xIce (Michelin) on his accord
    stay away from the artimax or any other snow tire that is studdable as consumer reports say those tires are really just all season tires with the ability to be studded. (unless you intend to use studs which I doubt anywhere in NE allows)
    don't buy any snow tires this summer as they will be leftovers from the last season. since rubber rots and you're only going to use them 4 or 5 months of the year and the tread hardly wears when driving in snow, I would wait as long as possible, the prius is FWD so it can handle the first few light snowfalls, but definitely get them before the first winter storm. My new Prius V has the wider tires so I will definitely need new snows this November. (I'm moving to Alaska!!)
  3. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    OK Thanks, yes tire rack has some discontinued Blizzaks ws-60 at $292 set of 4 , I think they dropped the price to move them. Ted
  4. cossie1600
    cossie1600 Active Member
    899
    92
    CT
    WS-60 are great, I use them on my car.
  5. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Please no talk of snow:eek:
    I am still waiting for it to be warm enough to melt the ice in my drinks :cool:
  6. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I use Blizzaks on my Prius and they did great this past winter. As you know, we got hit pretty hard here this last winter, and the DelDuh idiots only really plow main roads repeatedly then work on the other roads (we supposedly have a larger fleet than the city of Chicago, but they don't have issues like we do). I would recommend getting a spare set of rims and have them come mounted & balanced from TireRack. It makes it easier for you to swap on and off (or a shop if you have them do it).
    But, I'd put a vote in on the Blizzaks.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Ted,
    I would check out Consumer Reports' November 2009 comprehensive tests of a wide variety of all-season and winter tires:
    [​IMG] Consumer_Reports_Nov._2009_Tire_Tests-1.doc
    Note that unlike previous tests, you can compare tire performances across tire type categories. E.g., now you can compare a winter tire's snow and ice ratings directly against an all-season tire's snow and ice ratings.
    To me, the biggest surprise of these November 2009 tests is that they found an all-season tire -- the Hankook Optimo 727 -- with snow and ice performance that equals or exceeds those of most of the winter tires tested. (Although not as good as the very best winter tires tested.)
    As between the Altimax Arctic and the Blizzak WS-60, they rate the Altimax higher. But you can compare each tire's characteristics yourself and, given the factors that are most important to you, maybe you'll prefer the Blizzaks.
  8. mmichaell
    mmichaell Member
    241
    chicago
    Also keep in mind some of those Blizzaks have the grippy winter-compound on the rubber up to a certain depth of tread, and not throughout the rubber. That's one reason I chose other winter tires over the Blizzaks for my last car.
  9. RodJo
    RodJo Member
    423
    56
    Boston
    I went with the Michelin Xice2's. See the Consumer Reports' listing.
    But I would wait until the fall when new stock comes out. I remember mine had a buy 4 get back $70 deal. I don't think the total price was much different than the close-out price you've been given. And at least you won't get year-old tires.
    Because the rubber degrades over time. For that reason, most tires should be replaced after for 5 years or so, regardless of mileage. If you buy tires now you will get 1 year's less life out of them. Figure that into your math. Again, I would wait until October or so.
  10. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Given that most people are only going to get 3-4 seasons max out of a snow tire, I wouldn't worry too much about rubber degradation on a set of snows.
    I had Continental Extreme WinterContacts last year. Wasn't thrilled.
    Another tire definitely worth consideration is the Yokohama IG20 IceGuards. I had them on my Crown Vic the previous winter and the car was damn near invincible. Will probably pick up a set of the IG20s for this winter.
  11. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Thanks for all the input. I ended up going with the Blizzaks ws-60. Tire rack had them for $73 on a closeout before the ws-70's come this fall. Would have like the Michelin X ICE, but too expensive, The Altimax had lousy LRR according to CU. The Blizzaks seemed a good compromise and my experience with them on a 2000 Insight and 2009 Fit has been good. Thanks. all !!! Ted
  12. cossie1600
    899
    92
    CT
    You will love them, I have no complaints
