Solar Panel Ventilation problem
Discussion in 'Gen 3 Prius Technical Discussion' started by duraace, Jul 16, 2009.
  1. duraace
    duraace New Member
    44
    Vancouver, Canada
    With the car started (i.e. Power == ON), I depressed or turned ON the Solar Panel button, then turned the Power to OFF. I left the car in the sun for over 10 minutes. Returning with a long feather, I put it through the 2 inch opened sun roof, against the center vents, and NO air movement. What am I doing wrong? I haven't been able to get the Solar ventilation working yet.
  2. duraace
    duraace New Member
    44
    Vancouver, Canada
    Ooops ... working now. Not sure what was different. But the vents are blowing.
  3. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    why did you leave the sunroof vented? the solar does not need the sunroof vented to work.
    leave the sunroof closed, leave the car for over 10 minutes in full sun on a hot day. you can enter the car and feel the air flow coming out of the center dash vents. the fans turn off when you start the car, not when you open the door.
  4. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Please do not double post the same question in two different threads, it is not necessary. Thanks :)
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ** Dupes delete ** Woops, didn't realize they were merged. ;)
  6. Radon
    Radon New Member
    120
    Vancouver
    Your sunroof would be blocking your solar panel.
