solar powered secondary AC system for keeping cabin and battery temps down
Discussion in 'Prius v Accessories and Modifications' started by darknd666, Apr 18, 2026.
  1. darknd666
    darknd666 Junior Member
    171
    23
    Jacksonville, NC
    I have this (seemingly) wild idea to use a mini AC compressor, solar panel, separate or additional 12v battery, and a fan, all to keep the cabin cool enough to not over heat the battery, thus degrading it.
    My first idea which was low cost would have been an exhaust fan that I would mount to the rear cabin vent exit, which I believe is where the battery fan blows its air out, or at least tries to. I have not attempted this yet because I have yet to put ceramic film on the windshield yet, I must exhaust the more common tactics forst before I venture down this road.
    Now for the parts. There does exist a coke can sized compressor that uses 300W max and is variable speed so 100-300 watts. In reality this only needs to cool the immediate area of the battery, I can isolate/insulate the battery but in the event of a failure would heat the battery up even worse...
    Obviously there exists batteries and solar panels as well as charge controllers to maintain the system electrically. To keep the system hidden and clean a 100ah lifepo4 would be sufficient given an isolated charging system, bonus points if I can get the inverter to charge it and shut of the secondary HVAC, or fan when the car is running, whichever happens to more viable.
    For the AC a condenser and fan could be mounted externally, underside in the rear. As the power requirements add up, a larger roof mounted solar panel to lug around would be paramount.
    After further thought, I realized the engineering feat this would be as the cooling parts of the compressor would need to pass to the battery fan...or I could just AC the cabin for second place results.
    Another related question I pose is how I could maintain the 12v OE car battery via solar to lessen the load on the inverter, maybe gain some efficiency?
    12V Mini Compressor
    52,773
    you've got too much time on your hands :p
    search
    PrimeDan likes this.
  3. ChapmanF
    18,956
    Some gen 3 trims did this. They put a 60W-rated solar panel on the roof, and used it to drive the HVAC blower up front, switching the intake mode to fresh automatically, in case you had it on recirc. So it would bring fresh air into the cabin. The air would find its own way to the rear quarter exits, going through the battery on the way. (And you thought air was stupid.)
  4. BiomedO1
    BiomedO1 Senior Member
    4,517
    2,378
    Left Coast
  5. darknd666
    171
    23
    Jacksonville, NC
    Where might I find one of these solar panels to retrofit? Or are they generic? Im assuming not sunce this was OEM.
  6. darknd666
    171
    23
    Jacksonville, NC
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,001
    6,894
    Texas Hill Country
    I assume this Rube Goldberg contraption is to cool the battery when the existing ac system is off. Otherwise there really is no need in a standard hybrid with variable capacity hvac.
    Sometimes people think electronics and batteries have the same cooling needs as humans, which might have been true in the fifties with vacuum tube computers and sensitive magnetic media but is not 75 years later, especially in vehicles when they are not running.
    If there was any evidence the hybrid battery needed more cooling when running (which there is not because it has relatively small capacity), I would go with a solid state thermoelectric unit which could heat or cool the assembly, ideally with air flow reconfigured into a recirculated system.
    But the btus, energy and money required makes the existing air cooled system just fine. If we were talking modern plugins or evs, liquid cooling and heating using the vehicle's heat pump is the clear choice. Tesla's integrated cabin and battery system with simultaneous heating and cooling is a benchmark for ultimate efficiency.
    BiomedO1 likes this.
  8. darknd666
    171
    23
    Jacksonville, NC
    HVAC was bit of an extreme pipedream lol. If I could just get the fan to run when the car is off to evacuate the hot air or adapt the feature of the solar roof gen 3s that would suffice.
  9. ChapmanF
    18,956
    The cars with that feature have a different blower motor (with a brushless motor, to last longer given the increased run time), different wire harness, different roof and headliner, and a very Toyota-specific glass 60-watt panel on top. It's a nifty feature but makes me apprehensive in hailstorms.
  10. darknd666
    171
    23
    Jacksonville, NC
    Well is the fan physically different? I can look up the parts on ebay and see used ones. Im not worried about the factory solar panels, I can build a power solution for that easy. I may just double the 12v batteries and put a charge controller on a relay off circuit with an aftermarket solar panel on the roof (roof rack options would be nice). Or I could wire it up to a solar panel in the front, but the most economical would be to attach it to a roof rack cross bar system.
  11. ChapmanF
    18,956
    The fans are interchangeable. The brushless one is just more durable (and may be more efficient, to get more useful ventilation on days when the solar input might be marginal).
    darknd666 likes this.
  12. rjparker
    11,001
    6,894
    Texas Hill Country
    There is a post somewhere here where a guy modified the pulse width fan input to switch to an external pulse generator when camping. I believe he used a form c mechanical switch.
    However its one thing to do this at night and gain some benefit versus the neglible improvement that might occur in a high uv summer situation. Maybe drop 130f to 125f? In reality the hv battery temp is unlikely to change at all since it is somewhat insulated by the rear seat and hatch panels.
  13. darknd666
    171
    23
    Jacksonville, NC
    Im investing in repelling sunlight/UV first. The weathertech shades full set is a custom fit. I wont leave all of them on the windows, but the rear one I might leave there...carbon ceramic on the windshield would do wonders and its already in the pipeline. Baby step the improvements.
    After looking at a used fan for both a 2012 prius and a 2012 prius V, I cannot tell the difference other than a part number. gonna have to look up dealer parts to get a PN and then look for a used one. At least this way I have a spare I can butcher to experiment with, the brushless motor variant. Put in on a 12 volt supply at my work and experiment with thermistors, relays, we have solar panels at work too, I can mock up a configuration and then hash out a clean install later. We even have a heat gun i can test for a thermal sensor.
  14. darknd666
    171
    23
    Jacksonville, NC
    I need a good roof rail solution, something nice and permanent as I do have a roof basket I would like to use maybe in the future.
  15. darknd666
    171
    23
    Jacksonville, NC
    The V has a different part number between the brand 4 seasons. But the others its the same part between the V and a regular prius both 2015 years.
    Unless the images are reversed, the fans according to photos and part numbers are different. Gonna have to do an OEM part search. I did discover that the AC blower motor IS different because it says so in the part descriptions one for thise with the solar roof option and those without....and so the plot thickens.
  16. darknd666
    171
    23
    Jacksonville, NC
    Another interesting discovery, the blower motor for the solar roof option uses twice the amount of power, Nissens brand differs them 30 and 17 amps. I wonder if it puts out more CFM? More powerful HVAC capabilities? I could switch out the fuse and def have to check the wire gauge in the harness to make sure its capable of handling the current. I may ho deeper in the hole and pull up a wiring diagram to see if the solar vent control module can be used (unlikely). At this point of knowledge I would use the solar power to run the blower motor which should theoretically push air in from outside and out the rear cabin exits, hence the more powerful motor, that may be the best way to do this without getting complicated. The solar option fan is twice the cost new ill find a used one, if not ill just pay the $140.
    Solar controller will be needed, MPPT, ill have to find a way of designing a variable fan speed PWM controller behind a diode so current doesnt flow the other way when the engine is running normally as well as an ignition switch to cut it off.
    It may be that I design this to not use a battery at all for stored energy, If I were to utilize the 12V Battery system in the car I would use a low voltage disconnect on the fan so I dont end up with a dead 12V battery, probably set it kinda high too, prevent the depth of discharge from going anywhere near to the point of not starting the car. But the solar panel charging the 12V battery has its own risks.
    This brings me to my next point, the fan would use at most 30 amps....I would need more panel space in solar panels than the cars surface area would allow, hence the need for an MPPT to maximize current harvesting. Its unlikely ill ever be able to run the fan at max speed. This reopens my thoughts on utilizing a second battery to pick up the amperage when needed. A whole lot of thinking and revisions... reinventing the wheel so to speak.
    #16 darknd666, Apr 21, 2026
  17. darknd666
    171
    23
    Jacksonville, NC
    I need a high density quality panel for power, ive seen some that collect residual light on the underside from the casted shade.
  18. darknd666
    171
    23
    Jacksonville, NC
    Im assuming you were referring to the blower motors for the HVAC and not the battery
  19. darknd666
    171
    23
    Jacksonville, NC
    This is the panel I want. 15A at best should flow enough to drop the temps.
  20. ChapmanF
    18,956
    Right. Maybe I should have said it louder in post #3, but the factory solar roof option used the panel to run the HVAC blower under the dash. So it pushed fresh air into the cabin. The air, therefore, necessarily exited through the battery and the rear quarter vents.
    So the difference between blowers, brushless for the solar option, or conventional with brushes otherwise, is a difference between HVAC blowers under the dash, not between battery blowers.
    I don't know anything about where Nissens brand gets their ideas.
    The difference that Toyota documents between the two blower variants is just that the brushless variant has a longer service life, so it can run all those extra hours when you're not in the car. The wiring diagram doesn't show any difference in fuse rating (a 50-amp fuse is used in both variants).
    It certainly isn't there to be a more powerful blower and blow harder. Remember that the panel in the solar-vent gen 3 is rated 60 watts—in best conditions, unobstructed sun straight above the car, optimal temperature. At 12 volts, that's 5 amps, max.
    And they want the system to still move some air even in partial, morning, or afternoon sun. So the design objective is a blower that spins easily and efficiently enough that even at quite low power input it can usefully move some air. It will never be spinning at those higher input power levels except when the car is on and you're using HVAC and the car electrical system is powering it.
    As a little testament to how well the thing works at low input power, I modded my car to share power from the 60-watt panel to also charge the aux battery, and even after that, I still notice decent ventilation on sunny days.
    On days with less sun, you hear the blower running intermittently. It seems the "solar battery air conditioning blower vent ECU" contains some kind of storage element, maybe some capacitors. If the solar input isn't enough to run the blower continuously, the ECU will bank up some power, run the blower several seconds, and repeat.
    #20 ChapmanF, Apr 21, 2026
