Solved : Transistion to S4 without idle check.
Discussion in 'Gen 2 Prius Main Forum' started by uart, Mar 23, 2011.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    This is a technique that I've been using fairly often lately and it works really well. Ken1784 gave me this tip ages ago in another thread, but I get the feeling that a lot of people still don't know about it. That's why I'm making a specific thread for this so it will be easy to search on.
    The technique is simple, once you've warmed up just turn the car off (one second is enough) then turn it immediately back on.
    That's it. At first it doesn't sound very useful because you have to stop the car anyway to turn it off. So why is this any better than stopping for the idle check?
    Well there are two reasons why it's better. One reason is that's it's a little bit quicker. The idle check can take up to ten seconds whereas you can turn it off and back on in about four seconds (maybe even three if you're quick).
    That's not the main reason however. In fact if I do have to stop while the car is idling then I'll usually just let it do the idle check anyway. The real advantage of this "off/on" method is you can do it after gliding to a stop from above 55 km/h (34 MPH) while then engine is NOT running.
    You see my problem is not so much that my trips don't give me the opportunity to stop (traffic lights for example). The problem is more that I mostly manage to glide up to these stops from above 55 km/h, so the engine is already off and therefore no idle check occurs. With the "off/on" technique I can just flick it off and back on in about 3 to 4 seconds, even if stopped at lights without the engine running. :)
    Warning : Never try to turn the engine off while the car is still rolling. Above about 6 MPH it will just go into neutral so it wont turn off but no harm done. At about 6 MPH or below however it really will turn off, but it will slam it into "park" while doing so which gives the transmission quite a shudder. So always be at a dead stop before trying this.
    6 people like this.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Let me see if I understand the procedure correctly. The car is in S3 and glides to a stop. With my foot on the brake, I would push the power button to turn the car off, and then push it again (with foot still on brake) to go back to READY mode. This would bring the car from S3 into S4, right?
    Does this mean that the car will go into S4 automatically if the coolant T is greater than 157F when the car is first started? Or does it involve some short term memory of the state of the car prior to the starting?
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep that's it. Dont forget that you still have to put it back into drive though. :D
    Yes that's *exactly* right 2009Prius.:) In fact this technique first came to my attention for precisely that reason. In summer I noticed that I was sometimes getting to S4 even though I was 100% certain that I'd never been through the idle check! It really puzzled me and I couldn't figure out why, but eventually ken1784 clued me in to the fact that it would go straight into S4 at start up if the coolant temperature was already warm enough. Suddenly it all made sense and I realized that every time that I'd "mysterious" entered S4 that the car had been driven fairly recently and it was warm weather.
    5 people like this.
  4. cwa
    cwa Member
    Colombo
    thank you.
    How long it takes to reach the necessary coolant temp?
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It depends on the outside temperature and how hard you're driving. It's usually about 5 minutes or less for me.
  6. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Thanks for the info, this means that if I program my Spoofer to set the temp to around 185 at start on a cool day the transition to S4 could be effected.
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I guess it would, but I cant say whether or not it will be detrimental to the engine to bypass the normal warm-up cycle like that. I'd be a bit wary.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Interesting. I should try it also.
    There are situations where I never go into S4 because I come to a stop after going above 34 MPH in S3. ICE goes to 0 rpm after going above 34 mph so the car never performed that ceremony to enter S4.
    As a workaround, I put the car in B gear (as I slow to a stop) to force the ICE to spin. After coming to a stop, it performs the ceremony and enter to S4.
    This "off->on" sounds like a better solution. It is faster, doesn't require planning ahead and probably use less gas also.
  9. jstraw20
    jstraw20 Member
    122
    Long Island NY
    I'm going to try this later, but does this quick off and on still trigger the ICE to do the brief "top off charge" to the HV battery?
  10. hill
    8,805
    Um . . . if I remember, ken revealed this procedure over 2 years ago ... but who's counting.
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes, that's why I credited Ken in the first line of the first post. :)
    It's just that I noticed that many people don't seem to know about it. Also I think many people don't realize how useful it can be.
    Edit: Well I just checked and it was only 4 months ago (start of summer down under) when I posted the question about my mysteriously entering S4 without idle check and I can tell you that nobody knew about it then. The thread went on for several pages and everybody thought I was imagining it or that I had driven so slow at some point that it had done the idle check without me realizing it etc etc. Even some of the most senior members that normally have all the answers couldn't help me. Eventual Ken gave me the low down and it seemed as though he was the only one clued into this. But since his reply was a brief one "buried" on the third page of my thread I think that many people didn't see it and that most still don't know about it. This S4 problem is such a FAQ that I wanted a dedicated thread for it with a title that could be easily searched. :)
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah that's my problem too. And even when I deliberately try to plan a stop from below 34 MPH so that it can do the check I often get the lights go green (or another car comes up behind me at a stop sign) and I have to move off before the idle check is complete. It can be very frustrating.
    Yes the speed is a big advantage. I find that if I'm at the front of the queue at a red light then you can see what the lights are doing for the other direction so you always have time to do the "off/on" trick (because the time that the lights take to go amber - red in the other direction is actually all the time you need!)
    Also if you are half a dozen cars back in the queue then you still have time, because even if the lights go green just as you start the procedure it's always going to be at least 2 to 3 seconds before the cars in front of you get going. So even then you're probably only going hold up the line for about 1 second worst case.
  13. 2009Prius
    2,705
    512
    63
    We often give thanks to the post that gives useful information but forget to thank the post that ask the right question. Hint, hint... :D
    Just in case some people didn't know. Even if the ICE is already stopped at a stop, the S4 dance can still be easily done by holding the brake with the left foot and flooring the accelerator with the right foot to start the ICE to initiate the S4 dance. The "OFF->ON" method should be faster though.
    3 people like this.
  14. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Our JP Prius enthusiast's recommendation is 5 seconds power off period.
    Ken@Japan
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Another workaround if you were driving in D and came to a stop...
    • Keep in D with your left foot braking (or move to P), then flip your accelerator pedal to start the ICE. This procedure triggers the idling check ceremony.
    Ken@Japan
    4 people like this.
  16. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I was late.
    2009Prius is the winner.
    Ken@Japan
  17. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ken, I've been experimenting with it over the past few months at traffic lights and stop signs and I've found you can basically do it as quickly as it will physically let you (about 3 seconds for the complete cycle) and it still works.
    I do agree however that most electrical and computer related equipment prefers to be switched off for at least several seconds before the power is cycled. From my tests though I'm pretty sure that the "quick as possible" method is doing it no harm. Nothing that I've observed anyway. [​IMG]
  18. 2009Prius
    2,705
    512
    63
    Shouldn't you be sleeping at this hour? :)
    By the way hope your family is not harmed by the disaster. Best wishes.
  19. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Could I be clued as to why I would want to do this on my drive to & from work?
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    2 people like this.
