Sometimes I think I have lost my mind...
Discussion in 'Gen 2 Prius Main Forum' started by jelloslug, Mar 27, 2009.
  1. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Bonus points if you can figure it out. (It should not be that hard)
  2. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Yeah, you bought a Dell. Are you CRAZY?
  3. jelloslug
    813
    Greenville, SC
    4 years old and still runs like new (except for the keys I broke off the other day :der:)
  4. Patrick Wong
    18,200
    6,490
    Hi JS,
    Looks like you are viewing a page from the EWD, and that you have one CD loaded, but I'm not sure what problem you are trying to figure out.
    I also am partial to Dell.
  5. jelloslug
    813
    Greenville, SC
    Look a little deeper....
  6. TheForce
    3,461
    537
    Wheelersburg, Ohio
    One of these things just does not belong..... In that package. Right?
  7. jelloslug
    813
    Greenville, SC
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Wow, you installed a 6 disc changer and the system check showed OK!
    How much did you get the 6 disc changer for?
  9. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    There's also the fact that it's 11:30 at night and you're
    still going hard at it...
    _H*
  10. jelloslug
    813
    Greenville, SC
    And the JBL amp.
    I got the entire JBL setup minus the center speaker and wiring for free. Someone was just giving away the stuff to clear out space so I said "I'll take it".
    The wiring is straight forward. Run the network, power, and signal wiring from the head unit to the amp and then run the speaker outputs back up to the head unit area so it can go out to the doors. I will have to add a little wiring to the front doors to get the tweeters wired properly but other than that it will be a drop in installation. I would say that in the end I will have about $50 in it when you factor in the cost of the connector shells, the radio harness kit, and the ebay Corolla engine/dash harness I bought for parts.
    The way it is wired in the pics is just a test to make sure that it functions properly. Now I have to properly construct the harness and tuck it in with the other wiring.
