SPARK PLUG REMOVAL .... HAVE YOU SEEN HOW MUCH OF THE CAR YOU HAVE TO TAKE APART TO CHANGE THEM~?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by graham hendren, Nov 28, 2013.
  1. graham hendren
    graham hendren Geeman .. taximan
    82
    NOTTINGHAM ENGLAND. UNITED KINGDOM
    just looked at a video to change the spark plugs and you have to strip half the car removing whiper motors is going to the extreme omg . check the video on youtube its nutts
  2. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Not bad with 120,000 mile change interval.
    50,803
    that's why i trade in every 120k.;)
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    Remember the old days?...............We changed our spark plugs about two times a year and that was if you only drove about 10-15 thousand miles a year, plus replaced points, condenser, rotor, cap and wires also were changed. So if it takes a little extra work to change plugs at 120,000 miles. Oh well...........I can live with it.
    I agree with buying a new car before changing plugs anyway! :)
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    do it once its pretty easy only fifty screws
  6. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    At 51 I would have never bought a prius.
    milkman44 likes this.
  7. Mendel Leisk
    40,234
    I went through the procedure, to have a look at them. It is a royal pain. Our previous Civic Hybrid was almost as bad, but the wiper motors didn't need to come out.
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    It really isn't that bad to take off the wiper tray and wiper motor. I've done it at least twice. If you search on HAWAIIANBUILT's thread, there's a good description of the steps when he installed his Tanabe strut tower bar.
  9. canta
    canta Member
    101
    Raleigh
    No really painful comparingwth my previous(sold) V6 tiburon :p....
    at the end.,I never changed plugs. that was +160K when I sold with original plugs :D.
  10. Mendel Leisk
    40,234
    The reason for all this removal is an extension tube reaching down into the spark plug well. When you pull it up, it bumps into the underside of the windshield cowl one-or-two inches short of being able to be extracted. Therefore the need to tear out everything in that zone. Very frustrating, poor design decision.
  11. hlunde
    hlunde Member
    419
    75
    Vehicle manufacturer today make no effort to accommodate owners who keep their vehicles beyond perhaps 150,000 miles. On some vehicles replacing timing chain guides requires engine removal, valve adjustment requires camshaft removal, and spark plug replacement is often very time consuming.
    telmo744 likes this.
  12. Jose456891
    Jose456891 Junior Member
    34
    Rockville, Maryland
    Haha...
    Comrades, Changing Spark Plugs is not that bad, you just have to pull half of the car apart!!!
    At least its not a Mercedes, those things cost over 1k at the dealer to get the spark plugs replaced!!!
  13. GreenTea&SaltWater
    198
    58
    Los angeles
    Is it possible to remove the plugs without having to take apart the wiper system?
  14. ASRDogman
    ASRDogman Senior Member
    7,007
    3,668
    Not on a Generation 3 Prius.
    It's not that hard. About a 10-15 minute job...
    TGrracie and GreenTea&SaltWater like this.
  15. GreenTea&SaltWater
    198
    58
    Los angeles
    ok. got my car to start btw but it still feels janky. i posted an update on a new post
    TGrracie and ASRDogman like this.
  16. BiomedO1
    BiomedO1 Senior Member
    2,569
    1,380
    SacTown, Ca
    LoL, apparently you folks has never worked on a BMW mini. The entire front end needs to be removed, before you can get to anything - Break out the blow-torch :D:p:whistle:; lots of plastic and clips that break. You have to sell it before getting to 100K miles; otherwise your bank account will go negative and the bill collectors will be banging on your door. :ROFLMAO::LOL::eek::cool:.
    And don't get me started on the new Beemers without engine oil dip sticks
    Opps, never-mind - 10 year old zombie thread.......
  17. ChapmanF
    16,943
    It is if you have a Gen 3 built for one of the regions where people drive on the left. That version has different wipers and cowl that don't get in the way of the spark igniter removal.
    Here in the US, no such luck. The saving grace is, the wipers and cowl have to come out for so many kinds of job on the car that it gets pretty much like "chop ½ onion" at the start of recipes. You eventually sort of don't notice the time it takes.
  18. AzusaPrius
    AzusaPrius Senior Member
    2,132
    898
    Very simple and easy to remove all that.
    Like chapman said, it is like cutting onions.
    After doing it so many times, I have made a tool kit with the right tools just for the prius.
    That way I am not looking around my other tool box for the sizes and ratchet combos.
    So if I had a random ignition coil go out during a drive, I can easily do all that.
    Then I would find the nearest Autozone and swap it out since the ones I have come with a lifetime warranty.
    GreenTea&SaltWater likes this.
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    Impact driver. Takes me five minutes to remove the wiper arms and cowl. I timed it once. (I confess that I've done it scores of times and the first time must have been more like 10 minutes. :D)
  20. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Erm...... Yes.... You can do it by removing the wiper scuttle tray or you can just take off plastic cover remove coil packs and pull the plugs out using a couple of knuckles on a rachet... I'm not saying it's the correct method.. But it's A method... 5 minute job.
