spilled bottle of wine in cargo area of my car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rachael71, Jun 16, 2016.
  1. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    A bottle of wine exploded in my Prius today- well the cork popped off and all the wine is gone. I can't find where the liquid went-it was incredibly hot outside today and I thought maybe it evaporated??? It was in the cargo area- The car is driving fine but the only other thread I saw on this says this can cause damage to the battery- I am totally freaking out. I just bought it. I'm going to call the dealer tomorrow to have it looked at. Does anyone have any ideas what I can do to locate where the spill went or should I just take it to the dealer?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You know the Prius has a false floor right? The back part pulls up and voila, spare storage and a plastic bin. If you are lucky, it would be in there. Otherwise that false bottom, is another bottom! That's where the spare tire, jack, whatever is as well as the hybrid battery. That's where I would look. But it can seep down by the 12v battery all the way to under the rear bench seat.
    bisco and Rachael71 like this.
  3. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    I just looked there and there is some moisture but no liquid- When I found it earlier today, the foreward cargo mat has moisture on it but the mat area closest to the rear seat was bone dry- if it had gone into the spare battery area would it have drained from there or in plus hundred degree weather evaporated?
  4. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    well there's some liquid but not a bottle's worth of wine. I drove the car home not knowing how terrible this could be and it was fine..
  5. wjtracy
    wjtracy Senior Member
    11,358
    3,606
    Northern VA (NoVA)
    Where was the bottle when it broke?
  6. Mendel Leisk
    40,235
    Pull everything out, the subfloor tray, the spare tire and its tool tray. Pull out the two corner floor pieces. Then look everywhere, with a good light. Check under the 12 volt bsttery, for example. A wet/dry vacuum cleaner may be needed.
    Rachael71 likes this.
  7. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    It didn't break, the cork just popped off. It was in the cargo area-- But I just got back from Toyota- They looked over it and said I needed to clean the carpet and the some of the hidden areas, tire well, etc. Some got into the 12V battery well, but not much- They said nothing got into the hybrid battery well and said it was pretty well sealed off and it should be fine. So I pulled rubber mats out, pulled carpet pieces out and wiping everything with 401 K and then using pet cleaner on the carpet to get the smell out. None made it's way to the rear seat area. Toyota service guy said car was fine and just needed cleaning.
  8. wjtracy
    11,358
    3,606
    Northern VA (NoVA)
    I don;t have a Gen3 but I guess the carpet could absorb quite a bit of a wine bottle type volume.
  9. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    I never leave wine it a hot car. Even if the bottle (or cork in your case) does not break, the wine will be adversely affected. I use an insulated bag if I have a stop coming from the wine store. I agree with the others the carpet probably absorbed it. You may want to have it cleaned to prevent future odors.
  10. PosauneGuy
    PosauneGuy Member
    118
    88
    California, here I come...
    2025 Prius
    A bottle of wine (typically 750 ml) doesn't hold a lot of liquid...just a little over 3 cups. That could easily be absorbed by the carpet. (Hope it was white wine!)
  11. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    It was white wine! I have all the carpet pulled now, sponged with warm water and sprayed with Nature's Miracle- The pieces are sitting on top of my boyfriend's car now, basking in the sun.
  12. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    I learned my lesson the hard way! Thanks for the tip. I think I'm going to use an insulated bag/or better yet a cooler to tote liquids in the future- and never will I let wine sit in my car again. I feel so lucky that nothing more serious came of this.
  13. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There's a reason wine is stored in the cellar and not in the attic.
    I traced the deck carpet on to a large box to protect the carpet when hauling cargo.
  14. booke02
    booke02 Active Member
    391
    415
    Israel
    What can be more serious than losing a bottle of wine!
  15. Mendel Leisk
    40,235
    If pretty much a whole bottle of wine has disappeared into the hatch area, I'd want personally inspect, all the way to the low points. Chances are the dealership got someone on it, but I'd want to be sure, not discover a sticky grit trap later. Under the 12 volt battery for sure.
  16. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    There was a tablespoon or so of wine under the 12 volt- The service guy rocked the car to see if could hear sloshing, but he didn't. It doesn't sound super professional though, huh? Since the car has been cleaned by me, the smell has dissipated to a hint of Pinot Grigio in the cabin, rather than the smell of a wine bar after a busy night. Nature's Miracle worked very well to break up the wine smell. I really think the majority of the wine was absorbed by the carpet- So I will clean it once more and hopefully that will eradicate it altogether. I was just looking at my owner's manual, there's a section on how to remove the 12 volt. I will do that soon to get the last remaining sips of wine.
    Mendel Leisk and bisco like this.
  17. Rachael71
    Rachael71 Member
    50
    28
    Iowa
    Yes, haha. That was my first gut reaction. I hadn't even tried this variety yet!
  18. bisco
    50,805
    lucky carpet. a drink, a shower, and a good nights sleep.:p
  19. Mendel Leisk
    40,235
    Maybe the battery hold-down bracket can be loosened/removed, and the battery just raised slightly without disconnection, to better afford a peak under without loosing settings, and all the hassle. If you have a jump pack with a 12 volt outlet, there are memory saver cables, run between the jump pack and the OBD port, just provide 12 volt during battery disconnection, to avoid erasing memory.
