SSR Wheels for Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by FuelSpender, Jun 23, 2009.
  1. FuelSpender
    FuelSpender New Member
    22
    I already searched on this topic, didn't find anything on it, so i thought i would share since i posted the tanabe R&D thread.
    SSR Wheels
    SSR Wheels - Technology
    SSR Wheels - About
    (no, i don't work for either of these companies, or sell their stuff)
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi FS..,
    Interesting, but they do not list a 15 by 6 wheel for the Prius. The 8 pound 15 by 6 Type C wheel for the Insight, might not have the load rating needed by the Prius. If a 8 pound wheel was possible for the Prius, that would have a good benefit in pulse and glide operation and on bumpy surfaces at high speed.
  3. FuelSpender
    22
    I think the problem for the prius vs the insight is that the Prius has a very unique 5 x 100 bolt pattern vs the Insight which is a 4 lug. A lot of the smaller wheels only come in a 4 lug as a majority of those cars run only a 4 x 100 or 4 x 114.3 bolt pattern.
    So us prius guys are forced to go larger, but that also means more tire for us. :D
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    While low mass wheels do offer advantages, after having a set of 5Zigen wheels on my VW Turbo S I have a different opinion of ultralight wheels for street use. I hit a pothole at about 35 MPH (not that bad of a pothole) and bent one of the rims. In general, lighter = less strength. There's a limit on what is tolerable for street use, IMHO.
    Colton likes this.
  5. a_gray_prius
    2,927
    783
    IL
    Wow, I jsut checked the prices on the SSR Type-Fs (17x7.5, 15.3lbs vs 15lbs stock) and they're even more expensive than the Volk Eco Drives (16x6). The lowest price I could find on Google was $540 each without center caps. While I'd like to go up in size, I'd still rather run Volks.
  6. turnerdhr
    turnerdhr HellaFlush(TM) Prius
    SINGAPORE
    yes Mr Gray... VOLKS are always hot.... and the multi-spoked studded deep dish examples might suit the Prius better than the others.... ....
  7. FuelSpender
    22
    Why would you compare a 16 x 6 Volk to a 17 inch SSR? Reason i bring it up is because it seems like an apples to oranges comparison with complete different sizing.
    A 16 x 6 Volk would be an equal competitor with the 16 x 7 SSR Type F ( 5 x 100 bolt pattern ) which weighs only 11 lbs and retail is like $470 a pop. I am sure it can be had cheaper.
    http://www.ssr-wheels.com/wheels/typef_1516171819.asp
    It's better to just check by bolt pattern i guess.
  8. turnerdhr
    SINGAPORE
    yes, better to check by 5 x 100 pattern... no point looking at wheels at face value... not all wheels have the 5 x 100 pattern. better check by size e.g. 19 inch.. then 5 x 100 bolt pattern... then width and offset.... that will help narrow down the possible wheels without having to be led on....
  9. a_gray_prius
    2,927
    783
    IL
    Honestly it was just because I didn't see a listing for a 5x100 16x7. My mistake.
  10. silentbutfriendly
    silentbutfriendly Junior Member
    Miami
    What body kit is that on the white prius.
